It is currently Wed Jun 19, 2013 5:35 am
 Post subject: Freezing so bad I can't do anything
PostPosted: Sun Feb 03, 2013 10:55 am
I just finished building my PC, but i have been having some serious freezing issues, First it would happen while i was installing windows, but i finally managed to get that installed, then it would freeze while i was installing drivers. I had to restart it so many times that i corrupted some Windows files, so now i'm back to trying to install windows. Can anyone offer me any advice? I tried running the memory test from the repair windows screen, but the computer froze before i could get through it. I went into the BIOS and changed it from native IDE to AHCI, but that just caused it to jump through a bunch of error screens to fast for me to read, then go black. I have no drivers installed and i think that the chipset drivers may help, but i don't know how to install them without getting to the desktop. Any help is greatly appreciated.
Mobo: GIGABYTE 970A-DS3 AM3+
CPU: AMD FX-6100
GPU: XFX radeon HD 7850
Memory: (4gbx2) Crucial ballistics sport (only have one stick in now)
HDD: WD 500GB 7200RPM
Case: XION gaming series 980BK
 Post subject: Re: Freezing so bad I can't do anything
PostPosted: Sun Feb 03, 2013 11:31 am
The memory tester on Windows should be taken with a grain of salt. You'll need to run Memtest, choose the auto-installer to make things easier.
PostPosted: Sun Feb 03, 2013 9:50 pm
A couple of other things to check: What make and model of PSU do you have in this build? Does your motherboard have the latest BIOS revision installed?
PostPosted: Mon Feb 04, 2013 4:24 pm
The PSU is an Antec NEO ECO 620W, and no i don't have the latest BIOS.
