It is currently Thu May 23, 2013 3:28 am
 Post subject: Windows 7, won't work on first boot.
PostPosted: Fri Feb 01, 2013 8:01 pm
I just finished putting my computer together, and i'm installing OEM Windows 7 64-bit from the disc. after windows loads files, i get a black screen and error message that says:
"Windows failed to start. a recent hardware or software change may be the cause. to fix the problem, then it gives me the repair computer steps. it also says
File: \windows\system32\ntoskrnl.exe
Status: 0xc0000098
Info: windows failed to load because the kernel is missing or corrupt."
I don't know what to do because i can't access windows at all, is there something i can do in BIOS to fix this?
GIGABYTE 970A DS3
AMD FX-6100
XFX Radeon HD 7850
Crucial Ballistics (2x4)
 Post subject: Re: Windows 7, won't work on first boot.
PostPosted: Fri Feb 01, 2013 8:10 pm
No. You need a Windows install disk to do a repair install.
PostPosted: Fri Feb 01, 2013 8:19 pm
So if i only have the OEM disk i can't do a repair install? is there anything i can do?
PostPosted: Fri Feb 01, 2013 8:38 pm
If you can install Windows from it, you can do a repair install
PostPosted: Fri Feb 01, 2013 8:58 pm
http://www.maximumpc.com/article/how-to ... formatting
