It is currently Thu May 23, 2013 12:44 am
 Post subject: Win 2000 install issue
PostPosted: Thu Jan 31, 2013 3:18 pm
I having a problem installing win 2000 pro on my 2.5 laptop hdd connected by USB. I've tried everything. This hdd is for a pc tablet. If I go to boot xp on it, it will work. Every time I go to install windows 2000 on it the setup will say that the setup has determined that you computers hdd is new or has been erased or that your computer is running an os that is incompatible with windows 2000. I can continue by pressing c then press f8 to agree then there is no hdd to select from. Only shows my media card reader drives. Only have this issue with win 2000. Any ideas???
 Post subject: Re: Win 2000 install issue
PostPosted: Thu Jan 31, 2013 7:12 pm
You can't install Windows into an external HDD, if that's what you're trying to do.
PostPosted: Thu Jan 31, 2013 7:18 pm
Ubuntu installs perfectly. Win xp will install fine but when it goes to load xp it bsod right before it loads..I'm confused
PostPosted: Thu Jan 31, 2013 7:33 pm
http://www.tweakandtrick.com/2011/04/bo ... drive.html
PostPosted: Thu Jan 31, 2013 8:17 pm
I don't need a USB boot device. I need an os on this 2.5 hdd connect via USB to my desktop pc. Ubuntu is the only thing to work so far. Xp will install but crash when it tries to load. Windows 2000 setup won't even see the hdd but even win 98 will. The bios even sees it as an hdd. This hdd is for my pc tablet that can't boot from a USB or and external disk drive.
PostPosted: Thu Jan 31, 2013 8:32 pm
Debian works flawlessly externally, but you want 2000 huh? Okay, easy enough...just launch the W2K setup with the following command: winnt32.exe /syspart
This will cause the installer to place all of the installation on the second hard drive in a system. The drive must have a primary partition and be formatted for Setup to place the files.
PostPosted: Thu Jan 31, 2013 9:09 pm
Not sure what u mean here. Only thing see is press enter to install. R to repair or f3 to exit to install.
PostPosted: Thu Jan 31, 2013 10:14 pm
So... what are you trying to do and why does it have to be Windows 2000?
PostPosted: Thu Jan 31, 2013 10:24 pm
It's a hard drive for a fujitsu c-500. An old pc tablet that won't boot from a USB or CDROM. So I had to pull it out and put it in my desktop pc via USB. So it was to be win2k because of the specs if the tablet. Just having trouble getting windows 2000 install to see there's a hdd. I thought I wouldn't be this complicated. Been trying for almost 12 hours. No joke. No luck.
PostPosted: Fri Feb 01, 2013 3:23 pm
Are there any devices this device can boot from?
My initial thought is just do a diskless install.
http://www.easydesksoftware.com/i386.htm
You'll probably want to make the disk bootable by installing DOS (i.e. format c: /s) to start things out.
PostPosted: Fri Feb 01, 2013 9:12 pm
When I run the winnt32.exe from the win2k disk I get a internal error 2356. data1.cab
PostPosted: Sat Feb 02, 2013 6:42 am
Loading win 2000 on one computer then trying to boot in a tablet probably won't boot because it is totally different hardware to begin with. Did you hit F6 when trying to load win 2000 to add sata drivers via a floppy disk? (Assuming you are trying to load win2000 on a sata hard drive.) If you don't, you will never boot at all. It may not even find the hard drive.
PostPosted: Sun Feb 03, 2013 9:28 am
Then I'd say you're disk might be pooched...
or you need to start loading a config.sys with things like himem.
PostPosted: Mon Feb 04, 2013 5:47 am
It's a pirated copy of win 2000 disk. Works fantastic tho. I also Tried a legit copy and same issue. The comptuer was on xp when trying to run it. I'm thinking of trying to just clone the hdd to another hdd. And yes the settings will be differnt when put in the tablet. Ask fujitsu to correct the bios so I can boot the tablet from cd and USB :)
