| Clawhammer |
Joined: Fri Sep 23, 2005 6:22 pm Posts: 4406 Location: In the closet
You've definitely gone thru the right steps. But there must be another registry entry calling the plugin. Do this...
Perform clean boot and then uninstall. Clean boot will help us identify if any third party applications or startup items are causing the issue. To do this, follow these steps. After checking the functionality in clean boot, configure Windows to use Normal startup. Refer step 3 from the above link for details.
Check back with your progress.
