It is currently Tue Mar 03, 2015 11:28 am
 Post subject: Ghost Nic card won't go away
PostPosted: Mon Aug 16, 2004 11:43 am
I've got a Realtek 10/100 card that seems to have stop working, So I took it out and it won't stop detecting and installing even if it is out.
PostPosted: Mon Aug 16, 2004 12:09 pm
You sure this isn't from something else? Like an Onboard NIC??
PostPosted: Mon Aug 16, 2004 12:50 pm
Chief Surgeon
Chief Surgeon
If you've removed a physical card, and replaced it, boot Windows into Safe Mode, then go into Device Manager, and see if it's in there. If so, delete it.
If an onboard NIC went south, and you've replaced it, then you'll need to get into the BIOS and disable it there. Hint: Check "Integrated Peripherials."
SC64
PostPosted: Mon Aug 16, 2004 12:52 pm
Yeah this is a XP system, I've tried to get rid of it but keeps on detecting, I'll try the safemode removal real quick and see what happens
PostPosted: Mon Aug 16, 2004 1:05 pm
alright I went into safe mode and removed it, refreshed the Device Manager screen and it detected ethernet controler even with no possible ethernet card anywhere, No onboard ethernet also.
PostPosted: Mon Aug 16, 2004 1:26 pm
Maybe if I reset my ESCD in the bios I bet it's holding on to the ghost..
PostPosted: Mon Aug 16, 2004 3:36 pm
King of All Voodoo2 Cards
At this point I'd look into reinstalling WindowsXP, if the previously mentioned solutions weren't helpful.
