It is currently Sat Apr 25, 2015 6:50 am
 Post subject: iEEE 1394 Driver Problems
PostPosted: Sat Aug 14, 2004 9:22 pm
I'm running WindowsXp professional and somehow, my firewire ports no longer function (Not an add-in card) and it has the ! next to it in the device manager. When I try to reinstall its drivers, it asks me to get odd files such as "ntmaphlp.pdr" which I cannot locate, except the windows 98 versions. Any suggestions?
PostPosted: Sat Aug 14, 2004 11:19 pm
Chief Surgeon
Chief Surgeon
http://www.maximumpc.com/forum/viewtopic.php?t=1360
This will help us help you.
SC64
PostPosted: Sun Aug 15, 2004 4:13 am
Hi,
I did some Googling and found this on another forum:
"Win XP SP2 "turns Firewire 800 into Firewire 100" 55
THE MODERATOR of the RME forum has warned that installing Windows XP SP2 can lead to the bus speed being limited to 100Mbit/s. Matthias Carstens posted the message on the RME forum yesterday, but says it's not a problem particular to RME products. He said: "It affects any Firewire 800 device. If you have a FW800 PCI card and an FW 800 hard disk, go see the bits come one by one through the Firewire cable". RME, he said, was aware of the problem for some time, but "didn't really imagine that Microsoft would have the guts to try to bury an existing standard. We just downloaded the final public version and it is simply unbelievable". He said that some companies are trying to sell Firewire 800 drivers so everything will be hunky-dory. But, he said, these drivers probably won't work correctly with a Fireface 800. But phew, there is an answer. He said after the SP2 update, if you install the old SP1 Firewire drivers all will be well. "In our tests this solved all problems and brought back the old performance and compatibility". He said RME will release detailed instructions on how to do this today."
PostPosted: Sun Aug 15, 2004 8:48 am
Okay, I have not installed SP2.
And relevant system specs for the above person are as follows
Gateway 700 Series
2.8 GHz P4
1GB RAM
FireWire input leads to the sound card (Sound Blaster Audigy)
PostPosted: Sun Aug 15, 2004 9:45 am
Do you have the latest drivers for the sound blaster? You may have to get them from Gateways site and not Sound Blasters, they may have tweeked the drivers to suit them.
PostPosted: Sun Aug 15, 2004 9:51 am
One other thought, did you try to use the add new hardware wizard to reinstall the firewire? If you do, it will install the proper drivers.
PostPosted: Sun Aug 15, 2004 11:36 am
The gateway drivers are written in 2002, so they are quite old, but I used them. I also used the "Add new hardware" option, it still asks for ntmap.sys and those other files
PostPosted: Sun Aug 15, 2004 1:49 pm
you can get all these files it's asking for on google too:
http://www.network-drivers.com/drivers/60/60423.htm
It may take a couple attempts to get all the ones it wants, but you can eventually nail them all down enough to get it going.
The fact that these things are no longer there makes me think that you have a couple corrupt sectors on you HDD. They may have been in a spot at one point, then that block may have been corrupted and just aren't there anymore. a run of chkdsk (/r) may back this theory.
PostPosted: Sun Aug 15, 2004 5:06 pm
You can always try a "repair" with the XP cd, if the drivers are on the cd it should put them in place. As always back up any info before trying this.
PostPosted: Sun Aug 15, 2004 10:17 pm
Alright, I was hoping it wasn't gonna have to resort to reinstalling windows, but I guess I will have to.
And I tried those drivers that you linked me to, the problem is, they won't work on an XP machine :/
