It is currently Tue May 05, 2015 5:25 pm
 Post subject: Hard Drive Partition problem
PostPosted: Thu Aug 12, 2004 8:19 pm
When i baught my computer it came with a partition to act as a startup disk. well i didn't need that sense i had startup disks already so i deleated that partition. so now on my main drive i have 35Gb partitioned as my system drive and 5GB unallocated. i want to make it whole again so that my system drive is the full 40GB like it is supposed to be. can you help me?
PostPosted: Thu Aug 12, 2004 8:31 pm
i dont know why its 5gigs unallocated but i know that when you install the hdd and use partition it, you wont get the whole 40gigs. i used to have a 40gig and it would only come up as 37-38gigs. dont expect to use all the 40gigs you have on your hdd.
PostPosted: Fri Aug 13, 2004 2:31 am
team psycho or sumthin
i dont know if this will work but it let me use if on an old samsung 12gb HD
http://www.seagate.com/support/disc/dri ... scwiz.html
PostPosted: Fri Aug 13, 2004 9:32 am
i know its not going to be exactly 40 gigs and the reason i have 5 gigs unalicated is because i removed the partition that was acting as my startup disk.
PostPosted: Fri Aug 13, 2004 10:53 am
You'll just want to delete both partitions and just create one big partition. You can do this with either with fdisk, during 2000/XP setup, or with a HD setup program.
PostPosted: Fri Aug 13, 2004 11:36 am
Partition Magic will give you back that space.
PostPosted: Fri Aug 13, 2004 11:48 am
try this. My friend used to have I think it was about 10 Gb unallocated and he fixed using disk management.
control panel -> Administrative Tools -> computer management -> disk management.
See if that fixes your problem.
