It is currently Sun Mar 01, 2015 7:14 am
 Post subject: psu concern
PostPosted: Sun Aug 15, 2004 6:37 am
guys I installed this software not long ago and I notice that the power supply is not giving enought juice or so I think. Now, the thing is that I want to add a dvd burnner but I am not sure if the power supply will be able to give enough juice to it without reducing power to other components and damage them in the long run. Am I going to have to invest money on a better power supply? If so, what do u guys recomend.
Also, what dvd burnner do u guys recommend for a reasonable price?
specs
p4 3.01gz
GA-81875
Sound blaster live
80gb western digital
cd burner
1gb ram pc3200
GeForceFx 5700 ultra 128mb.
psu 400watts
thanks
PostPosted: Sun Aug 15, 2004 7:42 am
Sailorman
Sailorman
You can add your DVD burner. You will be no worse off than now as it will use the +12 power for the drive motor.
If I were you I would be thinking about a new PS though. Read this article. If you haven't been getting blue screens or other stability issues you may be OK. The +5 and +3.3 volt lines supply mobos and PCI/AGP cards with power. There is a section in this article that tells you how to test these voltages as software monitoring is notoriously inaccurate.
http://www.extremeoverclocking.com/arti ... ide_1.html
 Post subject: Re: psu concern
PostPosted: Sun Aug 15, 2004 8:01 am
I'd rather be modding!
specs
p4 3.01gz
GA-81875
Sound blaster live
cd burner
1gb ram pc3200
psu 400watts
thanks
The previous post is a good one - listen to him. Monitoring software values need to be taken with a grain of salt. The problem is they don't alwas get the right sensor. You will notice that CPU1 and your Mainboard temps are bogus (CPU2 looks right). On my machine, one of my 5V sensors (now set as -5v) reads 1.64 all the time. Also, you will notice that you monitor software says you have no CPU fan - that isn't true is it?
The 4.11v is still a bit bothersome though.
Manta
PostPosted: Sun Aug 15, 2004 9:08 am
thanks guys. I guess I will be adding the burnner and not worry to much about those numbers I am getting. BTW, what would be a good dvd for a reasonable price.
PostPosted: Sun Aug 15, 2004 9:40 am
Sailorman
Sailorman
http://www.newegg.com/app/ViewProductDe ... 947&depa=0
Plextors are preferred by some but you pay twice as much. I don't believe they have a dual layer drive yet.
I prefer Lite-0n's for performance plus affordability.
PostPosted: Sun Aug 15, 2004 9:56 am
thanks for the link. That seems to get the job done for a good price. I wonder if they have in white. Thanks for the link.
PostPosted: Sun Aug 15, 2004 10:09 am
Sailorman
Sailorman
They do but it is out of stock at the moment.
PostPosted: Wed Aug 18, 2004 8:49 am
if you have a generic or budge psu, it's probably not REALLY a 400watt unit, get yourself a good quality PSU. Antec is reasonably priced. You'll notice any 'flakiness' disappear too.
Bill
PostPosted: Wed Aug 18, 2004 9:32 am
I am sure is gereric as it came with my $40 case. I guess I will get a better one since I am planning on adding more storage and an optical drive.
