It is currently Sun Apr 26, 2015 5:19 pm
 Post subject: HELP! No computer
PostPosted: Thu Aug 12, 2004 4:45 pm
Alright I just got a brand new MSI K8N Platinum. And this is what happened.
When I loaded all my system I had a CMOS memory error so I cleared the CMOS, then went in to the BIOS and changed the setting for the boot sequence. This is the first problem and I was able to load Windows. Problem is, since I cleared the CMOS, I have not been able to plug in my usb devices. They are not getting power or anything. They did before I cleared the CMOS but not now. What do I need to do to load them back? I do have the BIOS set to USB v1.0 + 2.0 turned on.
Has anyone else had this problem or know what I can do. I have the motherboard off the metal plat with the provided extension screws. I can only use my keyboard in the PS2 port. Any ideas at what it may be or what I can do? And how to do it? Thanks so much for your help. I am in great need of my computer back after almost 2 weeks without
Thanks in advance
PostPosted: Thu Aug 12, 2004 4:54 pm
if it is directly related to the cmos, updating (flashing) the bios may help.... Im not sure though. best bet is to call the manufacturer
 Post subject: d
PostPosted: Thu Aug 12, 2004 5:01 pm
call the manufacturer, then if they say nothing fixes itself i would rma it. Sounds like something shorted out if the usb ports arent getting power.
PostPosted: Thu Aug 12, 2004 6:01 pm
you can definitely upgrade the bios of your mobo and see if that works.
PostPosted: Fri Aug 13, 2004 3:00 am
Excuse my bluntness here. I'm going through the Hardware haven posting this exact same message, so don't feel like you're being pointed out.
Any thread that has the word "problem" in it, or has the objective of curing a problem belongs in the "Free Clinic", not the hardware haven.
Hardware Haven: Discussion of hardware and technology.
Free Clinic: The emergency room. It's an HMO, but has great service...for free.
Thanks!
-Chumly
 Post subject: Re: HELP! No computer
PostPosted: Fri Aug 13, 2004 10:04 am
So you're saying that none of your USB products are receiving any signal from your computer?
Assuming you're running Windows XP, I'm guessing this isn't a driver problem or anything like that. If you have other USB connectors on your motherboard (you will) see if you have a front USB connection on your case and connect the wires from that to your mobo. Those are on a different channel at least, so they might get a response if you did in fact short something when you did a CMOS.
Or you can trying the CMOS again and resetting all your values to the way you like them and see if that will help.
But first, be sure they're on and that it's on hi-speed for USB 2.0. Some of your products may not be backwards compatible
PostPosted: Fri Aug 13, 2004 2:29 pm
Thanks in advance
Go into the BIOS and make sure that for some reason the USB ports have not been disabled within the settings. I have had this happen when I had to replace a CMOS battery once.
