It is currently Mon Jan 26, 2015 5:49 am
 Post subject: A crashed WinXP Profile
PostPosted: Wed Aug 11, 2004 10:21 am
Yeah yeah. i know better. don'y tweak the registry w/o backing it up first. I decided to play a little w/ the X-Setup app to tweak my WinXP profile. I changed a few settings a rebooted to test them out and now every time i use that particular user profile the system says loading profile setting and then reboots. I also hate the use of system restore so it was turned OFF. is there any ways to reset the profile settings to scratch w/o being in the profile??? System spec below...
ASUS A7N8X Mobo
AMD Athlon 2800+ Barton
2x 256k kingston Ram
Leadtek vid card w/ NVidia Geforce FX 5200 chipset
Samsung 52x CDROM
TDK 4x DVD+RW
Win XP Pro SP1
Jsatt
PostPosted: Wed Aug 11, 2004 12:21 pm
You should be able to login as the local administrator, go to the users folder and then rename the user.dat to something like user.old.
Of coarse this will load from the default profile. Anything beyond that, you'll be better served with system restore.
In all honesty, this might be something contained deeper then the user.dat, so you may have to rename the folder in it's entirty, and copy things back as you need them.
 Post subject: Re: A crashed WinXP Profile
PostPosted: Wed Aug 11, 2004 12:54 pm
ASUS A7N8X Mobo
Samsung 52x CDROM
TDK 4x DVD+RW
Win XP Pro SP1
Jsatt
If you login into an account with administrative rights you can go into the Documents and Settings and delete the folder with the name of the account. Restart the computer and it will be forced to rebuild the account all from scratch when you log into it again.
Another thing you can try is to get into System Restore and do type (without "") "chkdsk /r" at the prompt.
