It is currently Sat Mar 28, 2015 8:59 am
 Post subject: Winxp Video/Audio Skips every 60 seconds, VERY WEIRD
PostPosted: Tue Aug 10, 2004 4:43 am
I have been having some major headaches with my Sager Laptop (runs a 3.0 ghz p4, 1 gig ram, 128 meg radeon 9000). Everytime I play a movie file (be it divx, mpeg, or DVD), the video and audio will skip/stutter very badly nearly every 60 seconds for about 1-2 seconds. The remaining 58 seconds has perfect playback. I have done a reformat and nothing changed. I am using the latest radeon drivers and have tried some earlier ones too but no luck. Once in awhile I will get really lucky and a video will play fine for about 20 minutes then do the major skipping ever 60 seconds after that. I have also watched task manager and the process "SYSTEM" jumps from about 2% cpu usage to about 20% cpu usage during the 1-2 seconds of skipping/stuttering. I know it's not a heating issue because my cpu temps remain fairly low during the entire time. Any suggestions or ideas are greatly appreciated.
 Post subject: Re: Winxp Video/Audio Skips every 60 seconds, VERY WEIRD
PostPosted: Tue Aug 10, 2004 7:11 am
could the laptop have some hardware encoded feature for power saving? i say hardware because a format didn'dt solve your problem.
PostPosted: Tue Aug 10, 2004 8:36 am
Is the DMA turned on in Device Manager for the IDE controllers.
PostPosted: Tue Aug 10, 2004 4:32 pm
Yep, DMA is on and no, i can't find any hardware thing that is causing this. Someone suggested it could be with the directshow filters and I'm gonna try their suggestions tonight.
PostPosted: Tue Aug 10, 2004 6:43 pm
Are you sure you have the most current codecs? I don't just mean video, but audio as well. I used to have a similar issue, once I found the appropriate codec, it worked fine. Try looking for AC3 codec maybe?
Might not be your problem, but it's worth a shot.
PostPosted: Wed Aug 11, 2004 2:24 am
The problem seems to be fixed now. I downloaded this program called "Reclock" i believe. It basically sets a new clock to synchronize audio/video playback to the frame rate of the video file to prevent skipping. It looks like a lot of my problem came from the directshow filters of directx 9.0b. From what I can tell so far, everything is fine now while using this program.
