It is currently Tue May 05, 2015 9:40 pm
 Post subject: Some quick help please.
PostPosted: Mon Aug 09, 2004 8:35 pm
6800 GT
6800 GT
I'm a pc building newb, so with that out of the way, I'm about to install the motherboard into the case. What steps do I do? Do I put the cpu in before or after install, what about the heatsink/fan. Anything else I should know(dangers/tips)?
Thanks
PostPosted: Mon Aug 09, 2004 8:56 pm
make sure that u put the standoffs in the right place and the right amount
best to install CPU, heatsink, and RAM before install of mobo
be EXTREMELY careful installing the heatsink
that's all i can think of at the moment.
PostPosted: Mon Aug 09, 2004 9:09 pm
6800 GT
6800 GT
Ok Ive got
3 of these weird clip looking things that snap into holes in the case
10 brass standoffs
9 felt washers
assorted screws
the mobo is a gigabyte k8ns pro and the cpu is an athlon64 3000+
heatsink/fan is a gigabyte 3d cooler pro
PostPosted: Mon Aug 09, 2004 11:29 pm
6800 GT
6800 GT
got the mobo in as well as the cpu + heatsink
just gotta figure out where all these wires from the front of the case connect on the mobo
PostPosted: Mon Aug 09, 2004 11:41 pm
in my opinion thats the hardest part of building a computer, besides trying not to break the cpu on heatsink install.
PostPosted: Tue Aug 10, 2004 2:03 am
6800 GT
6800 GT
i got the
Turbo Case Aspire X-Dreamer II Black
theres a piece of paper included with a pin assignment on it but I dont understand it.
PostPosted: Tue Aug 10, 2004 7:13 am
don't forget the heatsink compound between the CPU and heatsink.
PostPosted: Tue Aug 10, 2004 8:57 am
Emwun Garand wrote:
i got the
What does it say?
somethings are easier to determine than others, like PWR = power (obviously)
PostPosted: Tue Aug 10, 2004 3:38 pm
Sailorman
Sailorman
The pin assignments should be in your mobo manual.
PostPosted: Tue Aug 10, 2004 8:13 pm
on the motherboards i have seen the pins for the front pannel leds and the on off were in the front bottom corner of the mobo and in your mobo manual there should be a page saying which is witch the only thing u should have a problem with if anything is if they included front usb ports that arnt a solid plug i have seen some that have the 4 different plugs you have to arrange in the right order other than that its simple as far as installin the computer the plastic standoffs are easy but personally i would align the brass standoffs into the correct places on the case install your cpu onto your mobo careful not to apply too much pressure on the actual chip on your amd chipset when dropping in the heatsink just go in lil by lil 1 side at a time then drop in the ram align your wires for your case drop it in and screw it down onto the brass standoffs but dont tighten it down cuz you dont wanna damage the mobo and most important make sure you dont have any stray metal pieces or anyother for that matter under your mobo that will short it out into your case and beyond that install the drives and the cards and u got it made :D
