It is currently Fri Apr 24, 2015 6:02 pm
 Post subject: need a program that mesure temperature inside the computer
PostPosted: Mon Aug 09, 2004 5:15 pm
i am not sure if this is the right place to post this question...but does anybody know of a program that can measure the temperature of my components?
thanx
 Post subject: Re: need a program that mesure temperature inside the comput
PostPosted: Mon Aug 09, 2004 5:20 pm
thanx
Do you mean something like this?
you'll need a bunch of sensors and according to your motherboard, it already has some that you can use.
PostPosted: Tue Aug 10, 2004 11:39 pm
You could also go with the tried and true MotherBoard monitor 5.
http://mbm.livewiredev.com/
