It is currently Tue Mar 03, 2015 9:02 pm
 Post subject: Help with downloading Win XP sp1
PostPosted: Sun Aug 08, 2004 5:46 pm
System:
Pent II 350mgh
128 mb ram
Old Asus mobo
I had to do a re-install, the problem I'm having is the "LAS shell (export version)" crashes when I try to get on Windows Update. As it scans my pc for for needed updates I get this problem. I checked the knowledge base and it list it as a Win 2000 problem and a memory leak(can this be right?).
I have had Win xp on this machine since Xp came out and never hit this problem befor. Any suggestions will help
Thanks
Edit: I'm just trying to find where I can download SP1 on my pc and burn it to a cd to install to this pos. :lol:
PostPosted: Sun Aug 08, 2004 6:22 pm
i dont believe that system even meets the minimum requirements for XP. ive gotten it to install on a 333MHz with 256MBs of ram, but it was VERY unstable and had to be reinstalled at least once a month ... could just be highly unstable on that system.
PostPosted: Sun Aug 08, 2004 6:29 pm
I thought that too a year ago when I first installed Win XP pro, but it seemed to work just fine(XP pro ran for almost a year, -15 days cause my Norton needed to be updated with a new subscription)). Stability was never an issue, This little machine even ran the Server 2003 when the Trial first came out.
Thanks for the imput tho :)
PostPosted: Sun Aug 08, 2004 7:15 pm
i dont know if this will work but try changing your page file. people say that the minimum and maximum for your page file is twice that amount of your ram. since you ram is 128megs, change your min and max to 256megs. good luck on that issue.
PostPosted: Mon Aug 09, 2004 9:08 am
Physically, your system is fine .. of course, you know this since you ran XP on it for a year. :)
I would start by checking for viruses and other related nastiness ... I'll bet your problem is related to a piece of malware hiding on your PC somewhere.
Good luck!
PostPosted: Mon Aug 09, 2004 9:17 am
Phoenix Foundation (Top 10)
Funny, I had a P166 sitting here running XP Pro with only 64mb RAM, ran just fine actually. I believe you asked about a download link for the SP, so here it is.
http://www.microsoft.com/windowsxp/down ... fault.mspx
PostPosted: Mon Aug 09, 2004 11:38 am
Thanks for all the help :D
