It is currently Sat Apr 25, 2015 1:43 am
 Post subject: OK where to put server on the network now.
PostPosted: Sun Aug 08, 2004 12:41 pm
I have ran just a simple file server with Windows 2000AS and Apache doing web duty for awhile. I just got a great deal on The Win2003 SBS Premium Edition with outlook and FP W/5 CAL's.
What I have on the network
1. Toshiba Cable Modem
2. Buffalo G54 Air Sation W/4 port router and repeater
3. Linksys 24 port auto-sensing hub
4. My machine
5. wifes machine
6. HTPC
7. Back patio entertainment PC
8. And of course the server
I want to setup the whole ball of wax this thing comes with(Domain,Exchange,etc)
What I don't know is how and where the server should sit on the network for this level of networking.
Do I set it after the router and allow the router to continue doing DHCP functions, Behind the router but dummy down the router, or in front of the router with a nice firewall on it and use the router only as a WAP?
What is going to be the easiest way for me to get it up and running? First and foremost is ease, so I can get my feet wet, then I will tighten it down and work on anything else.
Oh ya, I ask this because I installed it all already and currently have the server behind the router on the hub.
I couldn't figure out how to get it all working yet , so I wanted to just dummy the server down and join it to the basic workgroup I had going.
Well now the machine shuts down after 2 hours with a message telling me I'm in violation of the EULA because this machine has to be configured as a DC.
So this has prompted me to get my ass in gear and learn how to get it all setup even if it kills me. I need my files for more than 2 hours at a time (go figure lol)
PostPosted: Sun Aug 08, 2004 4:02 pm
Are you going to be accessing the server from the internet or only from your home network?
If you're going to be only using it at home, then I would leave it where you have it.
Oh and setting up the domain isn't that hard, just make a shortcut to the Active Directory Users & Computers utility.
I don't like SBS because you can't trust domains or anything nifty like that.
PostPosted: Sun Aug 08, 2004 5:12 pm
I don't see what choice you have but to plug it to the switch.
You can continue to let the router handle DHCP, but I beleive you'll have less headaches by assigning that SBS machine a static.
PostPosted: Sun Aug 08, 2004 6:37 pm
Accessing it from the net would be nice but I guess not necessary. Why are domains unreliable. I do plan on assigning it a static on the network.
PostPosted: Mon Aug 09, 2004 7:43 am
It is a limitation of SBS. Trusting domains allows you to access resources on another domain, which isn't very useful in your case. It is very bad if you are a company that is migrating from one domain to another.
I would disable DHCP on the router and use the server to assign DHCP.
 Post subject: Re: OK where to put server on the network now.
PostPosted: Mon Aug 09, 2004 11:46 am
let the SBS do the DHCP duties and disable the one on the router.[/quote]
