It is currently Sat May 25, 2013 11:58 am
 Post subject: install of PATA card drivers (floppy required?)
PostPosted: Tue Dec 04, 2012 6:21 am
I'm having some trouble with my Masscool XWT-PCIE11 PATA/SATA PCI-E adapter.
http://www.newegg.com/Product/Product.a ... 6815280009
(Every so often,my Hitachi 1TB hard drive and one of my optical drives decides to disappear,then reappear after a reboot.)
I thought I might try installing updated drivers for the JMicron chipset on the adapter,but it says to use a floppy disk for the install.
(Does the setup.exe included in the download work to install the drivers?)
(Think I answered my own question-it doesn't need a floppy for installing drivers.)
Hopefully this will fix my problems.
 Post subject: Re: install of PATA card drivers (floppy required?)
PostPosted: Tue Dec 04, 2012 2:01 pm
usually when you start seeing floppy, you're talking real mode drivers needed to boot media (i.e. F6 to load additional drivers).
