It is currently Sat Jan 31, 2015 10:30 pm
 Post subject: External Drive Install Question
PostPosted: Tue Dec 04, 2012 8:04 am
Waiting for a USB 3.0 PCI adapter to come in the mail. Buying a WD 3TB external drive today.
My Win 7 install was done with IDE settings on NOT AHCI. Can I plug my new external drive into one of the USB 2.0 ports and install drivers, firmware updates (I think I have to do a format cause it's 3TBs) and then successfully plug it into the USB 3.0 adapter when it shows up without any problems?
 Post subject: Re: External Drive Install Question
PostPosted: Tue Dec 04, 2012 2:06 pm
SATA settings (AHCI or IDE) has nothing to do with using USB (be it 2.0 or 3.0) hard drives, so install away
PostPosted: Tue Dec 04, 2012 2:11 pm
Yes but it could conflict with your PCIE slots.
@ furball, c'mon just play along. :wink:
PostPosted: Tue Dec 04, 2012 5:02 pm
I know the safe thing to do is to wait for the PCI adapter to come and install the new external drive with the new USB 3.0 port but.......who does anything safe?!?!!
Just figure I could get a head start and load drivers, update firmware and even start to backup files to the drive. I should be able to just shut down the pc, unplug from USB 2.0 and plug it into the new USB 3.0 adapter when it arrives.....right??? It will see it as new hardware and find the drivers already loaded into the system?? As opposed to AHCI which allows hot swapping.
edit - yeah, now I think about it IDE/AHCI is for the SATA ports. The fact that mostly hard drives plug into them had me thinking the USB ports were included too but I guess they are not.
PostPosted: Tue Dec 04, 2012 5:19 pm
1. There are no drivers to install/load. Windows will do this for you.
2. There's no reason to update the firmware on your devices unless it's absolutely necessary.
3. All Windows sees is a USB to hard drive adapter. It doesn't care if it's IDE/AHCI.
PostPosted: Wed Dec 05, 2012 10:39 am
Ohhh man, you most of all know when it's time to pull some wool and play. Whaddya doin?
Users browsing this forum: No registered users and 13 guests
