It is currently Sat Jan 31, 2015 6:27 am
 Post subject: Question on the PSU's in my server.
PostPosted: Sat Aug 07, 2004 4:21 pm
First of all I just put the third PSU in my server due to failure. None of them were cheapies.
The first was an Enermax EG465P-VE. It died after approximately 3 months of use. One hell of a short life. At the time it was only running 3 drives.
The second was an Antec True 480. This time I got 5 months with 4 drives running.
Now I am on a Vantec Stealth 470. I hope this time I get a little more life, but I also added another drive for a total of 5 in my server now.
So my question is, do I need better case flow, or just a better case period. The server is housed in an ancient Antec full tower case. This is the only thing I can think of that is killing these PSU's. However I think or thought the precautions I took would be adequate for cooling. Maybe I just need an even better power supply(PC Power and Cooling), if I want to run this many drives 24/7?
For a side note, when they died, they didn't die completely. The first one would make me flip the switch off for 30 seconds then back on and it would boot. The second was playing hell with spinning up my drives on boot. In fact the second made me think I had HDD failures this time, but I couldn't see more than one drive going at the same time. I was right because with the fresh PSU it boots like a dream.
The complete specs:
Tyan S2460 TigerMP
2X Athlon 1800+ MP's (2X SLK800's)
1GB Kingston ECC Value RAM
nVidia TNT 32MB(dont know much about it, but it works lol)
Intel Pro 100 NIC
Promise Fastrack 100 TX2
Cheap Silicon Image based ATA 133 RAID controller
1X80GB WD SE drive (30GB part for OS 46GB Part not determined yet)
2X100GB WD RAID0 for network storage (Music,Video,Images,Programs)
1X160GB Maxtor 8MB for Music,Video,Images backup
1X100GB WD for programs and misc backup
Pic of inside case for airflow critique.
PostPosted: Sat Aug 07, 2004 4:43 pm
do you have a ups hooked to it?
have you put your hand on the psu to see if it was getting unusually hot?
PostPosted: Sat Aug 07, 2004 5:01 pm
Yes it is on a UPS(sorry should have added that).
No I never touched the PSU as I never had the sides off while running it. Where I place it is a PITA to get to it, so I have to disconnect it and take it out for servicing. I will keep an eye on that this go around.
My case temps were just 3* above ambient too. Then again the temp sensor is at the bottom of the case, so that doesn't tell me if there is a hot spot up high.
PostPosted: Sat Aug 07, 2004 10:23 pm
could be dirty power...
i dont think heat is an issue, unless you load it up with dust
PostPosted: Sun Aug 08, 2004 12:21 am
Holy hell dude, I could start to think what the deal is. Those PS's are good ones, so I hate to blame them at all. I have a True480 that's had a rough life for 2 years and it's still running fine.
I'd like to point at some odd power problem, but can't think of an easy way to test the outlet. And AFAIK, the UPS will just let dirty power go by and is looking for spikes and what not. If, for some reason, you're getting some (I dunno) squares or something thrown in there, it may not see it.
PostPosted: Sun Aug 08, 2004 7:22 am
Maybe I should replace the UPS and plug into a different outlet then? It is a 2 year old UPS, and when I bought it it was the cheapest APC available. I will try that. I'll go out and get one this week.
Another question. This Vantedc I have in now is very steady and tight. None of the rails deviate more than .01 either way. However the 5V rail is only showing 4.62V. is this ok?
I'm thinking it's not getting read correctly. I never really paid much attention to the rails before, but since this is the third, I am watching this PSU like a hawk lol.
PostPosted: Sun Aug 08, 2004 3:38 pm
if you have a multimeter, check the outlet and if you can see what else is on the same line the outlet is connected to
probably..check it with the multimeter just to be sure
PostPosted: Sun Aug 08, 2004 4:07 pm
I would try a different outlet. I suspect that the power outlet is supplying very bad power.
Do you know anything about the quality of the wiring in your house?
