It is currently Thu Mar 05, 2015 8:42 pm
 Post subject: AGP Voltages
PostPosted: Wed Aug 04, 2004 3:47 pm
Ive had some problems with my agp slot on my previous mobo. I am getting a new one and it says that it doesn't support 3.3v cards. Which cards are at this voltage? I have a 9800pro. This should work right? Also, what is AGP Pro 50? It says it supports this, i've never heard of it. Thanks for any input.
PostPosted: Wed Aug 04, 2004 3:57 pm
AGP Cards that use 3.3v are older types, like a TNT and the like. Most newer cards use 1.5v, which is the AGP 8x standard.
AGP 50 is a workstation variation that gives the videocard more power than a normal AGP slot can. AGP50 cards generally don't need the extra power connector that R360/NV35 cards do.
PostPosted: Wed Aug 04, 2004 4:20 pm
AGP Pro is workstations
PostPosted: Thu Aug 05, 2004 10:33 am
Cool! Thanks for the info. So If it supports .8v and 1.5v all cards i buy in the future should work right?
PostPosted: Thu Aug 05, 2004 11:22 am
Yes. No one makes 3.3v cards anymore.
IIRC, the last 3.3v card was the Voodoo5.
PostPosted: Thu Aug 05, 2004 12:29 pm
Hahah. Thanks!
PostPosted: Thu Aug 05, 2004 2:18 pm
there are still a couple that suppot 3.3v(1x, 2x) and one of them is a DX9 card too :shock:
PostPosted: Fri Aug 06, 2004 8:18 am
The cards may SUPPORT 3.3v but they aslo support 1.5v. The cards only use 3.3v when they are plugged into AGP 1x or 2x slots that only push 3.3v. It's called backwards compatibility.
PostPosted: Fri Aug 06, 2004 9:21 am
true, I was hoping you'd find it amusing that a DX9 card would even run in 1x,2x :)
