It is currently Tue Mar 31, 2015 1:32 pm
 Post subject: DoS attacks
PostPosted: Tue Aug 03, 2004 3:54 pm
using Sygate Personal Firewall on my Windows 2003 Server, the Security Log is constantly picking up a Denial of Service attack from the same Mac address (IP varies).
the IP is very close to my own, so i'm assuming it's someone close to me, seeing that i'm using cable broadband.
is there something i can do about this? report to abuse@earthlink.net with the IPs and Mac?
PostPosted: Tue Aug 03, 2004 6:09 pm
are you sure it's a dos attack and not some goof(s) trying to crack your server?
what are the IP #'s?
PostPosted: Tue Aug 03, 2004 6:15 pm
no, i'm not sure what they are, and i don't really know what exactly is a DoS attack either.
the IPs vary, but all start with 24.x.x.x and most of them are 24.233.x.x.
PostPosted: Tue Aug 03, 2004 6:36 pm
a dos attack is a bunch of computers flooding your server at the same time with repeated garbage requests just to tie all your bandwidth so nothing else can get in
have you had alot of port scans lately?
PostPosted: Tue Aug 03, 2004 7:43 pm
probably not. only thing showing up on the log is the DoS attacks.
PostPosted: Tue Aug 03, 2004 8:08 pm
is your server open to the public(file shareing, web pages, etc..)?
PostPosted: Tue Aug 03, 2004 8:32 pm
web server is the only public one. FTP, mail, and file sharing, i'd consider private, since there's no anon login.
PostPosted: Tue Aug 03, 2004 11:55 pm
you're probably just getting alot of pings from infected computers.
I'd only worry about it if your log shows alot of activity directed at one port over a very short period of time or if someone is scanning through a series of ports in a short period...when I say short period I mean less than a minute.
lately I've been getting pinged like crazy(about every 1-2min) and I'm not running any services...every time a new batch of virii spreads it gets like this. My isp even sent out letters last year telling alot of them to clean up their computers(blaster iirc) :shock:
take a trip over to grc and run the sheilds up test
 Post subject: Re: DoS attacks
PostPosted: Wed Aug 04, 2004 3:28 pm
You can do a whois search on these IP address to see who owns or controls them. Are all these DoS attacks using the same ports to get to your pc?
Remember many times these IP address can be faked using software. It is called spoofing.
PostPosted: Wed Aug 04, 2004 7:38 pm
the reverse lookup shows that they're on Earthlink or Road Runner, doesn't show what port it's going thru on the firewall, but they're all from the same mac address.
PostPosted: Thu Aug 05, 2004 8:14 am
If the "attacks" are coming from your ISP then it's harmless. ISPs routinely check on what's being used.
PostPosted: Thu Aug 05, 2004 9:26 am
i don't know if it's from my ISP or not, all i know is that it's someone with the same ISP as me.
PostPosted: Thu Aug 05, 2004 8:21 pm
Try running a few different test at http://www.dnsstuff.com. It might provide some more information on the IP address you keep seeing in your logs.
Users browsing this forum: No registered users and 13 guests
