It is currently Thu Jan 29, 2015 9:36 am
 Post subject: Double-click on "C" or "D" goes to "search."
PostPosted: Thu Nov 15, 2012 4:36 pm
What gives? Anybody know the fix? :?:
 Post subject: Re: Double-click on "C" or "D" goes to "search."
PostPosted: Thu Nov 15, 2012 4:49 pm
What're you talking about?
PostPosted: Thu Nov 15, 2012 6:45 pm
Go to start then run then type regedit. Go to HKEY_CLASSES_ROOT\Drive\shell. Modify the default and change the value data to "NONE". Your problem will be solved.
