It is currently Wed Jun 19, 2013 7:01 pm
 Post subject: Disc drive Malfunctioning.
PostPosted: Tue Nov 13, 2012 9:08 am
On my old ass IBM think pad t42 the optical drive has suddenly quit working and not just in windows either also in Linux i think that the on-board firmware for the drive needs re-flashed any idea? Also any tools that could help me re-flash the firmware this thing is ancient the only reason i keep it around is for some older games I run, which it is currently useless with out a disc drive for the most part. It started with DVDs then went to CD's i will update this post with the drive model number and manufacturer tomorrow.
 Post subject: Re: Disc drive Malfunctioning.
PostPosted: Tue Nov 13, 2012 9:33 am
Firmware suddenly going bad on a part is very unlikely, and since they rarely need updating, I wouldn't be surprised if firmware on optical drives are ROMs. If you can find the manufacturer, it wouldn't hurt to check if there's a diagnostic tool. However, at the same token, it might be easier to go to your local brick and mortar electronics shop and buy a portable drive. They're around $30.
But I could be wrong, the firmware could exist on flash in an MCU and for some reason the lock on it doesn't work.
PostPosted: Wed Nov 14, 2012 2:54 pm
Ditto....unless there's some piece of info that would make you automatically leap to that conclusion...like you tried some firmware and it hiosed evyerthing...
PostPosted: Thu Nov 15, 2012 5:59 am
search a little for you you can get a new one for $14.50 on ebay buy it now and us only here is the link http://www.ebay.com/sch/CD-DVD-Bluray-D ... =1&_sop=15
