It is currently Mon Apr 20, 2015 10:12 pm
 Post subject: USB port not recognizing one device (solved)
PostPosted: Mon Nov 12, 2012 6:47 pm
Million Club - 5 Plus
Device to be connected:
Behringer U-Control UCA202 USB audio interface with digital output
http://www.behringer.com/EN/Products/UCA202.aspx
Machine 1
Emachines W3118
Motherboard FIC K8MC51G
AMD Sempron 3100+ 1.8GHz
768MB PC3200 RAM
WD 80GB WCD800BB hard drive
Nvidia GeForce 6100 onboard graphics
Realtek onboard sound
Windows XP Home SP2 (fresh install from restore disc after "Missing Operating System" boot error message)
Machine 2
Toshiba L305-S5944 Laptop
Intel Pentium T3400 mobile processor dual-core 2.16GHz
2GB PC6400 RAM
250GB SATA hard drive
Mobile Intel 4500M graphics
Intel onboard sound
Windows Vista Home SP2
Machine 3
Asrock 880GM-LE motherboard
AMD Athlon II x4 640 3.0GHz
4GB Kingston DDR3 1300 RAM
WD 160GB WD1600AAJS SATA II hard drive
AMD onboard HD4250 graphics
Diamond Xtreme 5.1 PCI soundcard
Windows XP Home SP3 and Windows 7 pro 32-bit
Here's the situation.
When connecting the Behringer USB audio interface to Machine 1, it is not seen or recognized by Windows. There is no prompt in the systray and it does not show up as a USB codec in Device Manager as it should. The USB indicator on the device lights up when plugged into a USB port.
When connecting any other USB device to Machine 1, (thumb drives, digital cameras, keyboards, mice, etc.) it is immediately recognized by Windows, the driver software is installed automatically, and it's ready for use.
When connecting the Behringer USB audio interface device to Machine 2 or 3, it is recognized immediately by Windows, the driver is installed automatically, and the device is ready for use.
So... what's stopping Machine 1 from seeing the USB sound device? Any ideas?
 Post subject: Re: USB port not recognizing one device
PostPosted: Mon Nov 12, 2012 9:30 pm
I can see machine 2 and 3 (on Windows 7) picking it up immediately for having generic drivers and machine 1 not because it may be too old.
PostPosted: Tue Nov 13, 2012 4:39 am
Indeed. Remember back in those days drivers were wonk and a 50/50 proposition to work. #1 is an old rig. What is the mobo on that thing?
PostPosted: Tue Nov 13, 2012 7:20 am
Sorry, I forgot. The mobo is an FIC K8MC51G.
http://www.fic.com.tw/product/motherboa ... MC51G.aspx
Processor Supports Sempron Athlon 64 processors (Socket 754) / FSB Up to 1GHz
Chipset North: NVIDIA C51G / South: nVidia MCP51G
Memory 2 184-pin DDR DIMMs / Support DDR 333/400 SDRAM / Supports a maximum memory size 2GB
Video On board Controller Embedded in nVidia C51G / Add on interface 1x PCIe by 16
Audio Controller nVidia MCP51G / Codec ALC 655 5.1 Channels
Onboard Lan Controller+PHY--MCP51G+ Broadcom AC131 / Support 10/100 Mbps
Expand Slots One PCIe x 16 / One PCIe x 1 slot / 2 PCI
Onboard IO 1 Parallel Port / 2 PS2 Connectors / 1 x COM port ; 1 x VGA port / 1 (1 x RJ45 + 2 x USB 2.0) / 1 x Audio connectors : Mic-In, Line-In, Line-Out / 1 x (2 x USB 2.0)
Onboard IDE An IDE controller on the NVIDIA chipset provides IDE HDD/CDROM with PIO bus / Master and Ultra DMA 100/133 operation mode
System Bios ACPI, APM, DMI, SMBIOS, PnP, USB, PC99, PC2001, Y2K Compliant
USB 2.0 8 USB2.0 ports
IEEE 1394 Supports up to 2 x 1394 ports (Optional)
Form Factor uATX Form Factor - 9.6(L) x 9.6(W) (unit : inch)
Serial ATA Controlled by NVIDIA MCP51G / SATA II PORT 2 port with 3GB/s support
Everything I've read about the Behringer in various places says that it's compatible with OSes going as far back as Windows 98SE.
PostPosted: Tue Nov 13, 2012 7:59 am
I know you are astute, but I just gotta ask. All the drivers are freshly installed, right? No remnants of upgrades or patches from the XP hinteryears? This audio device was a bit beyond what XP had in mind back in the day when usb connectivity was just gestating.
PostPosted: Tue Nov 13, 2012 10:17 am
As far as I am aware, all the drivers for the mobo are up to date. The XP install is fresh from the restore discs, with all the bloatware removed.
But I was unaware that the Behringer device had drivers available. Thank you for that link! I'll need to pick the right one and try again as soon as I can.
 Post subject: Re: USB port not recognizing one device (solved!)
PostPosted: Fri Nov 16, 2012 5:53 pm
Problem solved! :D
The Behringer USB device being connected to Machine 1 is recognized and a driver is automatically installed by Windows XP.. there's just no pop-up balloon notification nor does it put an icon into the System Tray as other new USB hardware devices do upon detection.
The device shows up in Sound Properties in Control Panel as "USB Codec", and it works perfectly when connected to my friend's Akai Miniak keyboard.
Thanks for the insight, kleinkinstein, Latios. Very much appreciated.
