It is currently Mon Jan 26, 2015 3:23 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 02, 2004 9:44 pm
coffee wrote:
CHUMLY...what do you mean??
"disabled any services as per the magazine as well.
The magazine did an article informing readers of services that we may be able to disable. Some of them were network related...just a side thought.
PostPosted: Tue Aug 03, 2004 8:01 am
defkhan1 wrote:
Can you open shares by typing \\MACHINENAME\SHARENAME in the RUN box?
Is NetBIOS or WINS enabled on the internal network?
They are not enabled...
I was under the assumption that I did not need these.
PostPosted: Tue Aug 03, 2004 8:45 am
NetBIOS is the next generation of BIOS and is routable. BIOS is not.
PostPosted: Tue Aug 03, 2004 9:09 am
INFINITE vCORE
INFINITE vCORE
I THINK NetBIOS provides name resolution for your private network and without this enabled you may only be able to connect to other machines via IP address...
I believe if you're not running Active directory and DNS for naming, then you will need NetBios to connect via machine name...
But I am not a network guru, so I post this with my own grain of salt ;)
PostPosted: Tue Aug 03, 2004 2:10 pm
Here is some additional information on NetBIOS. http://www.webopedia.com/TERM/N/NetBIOS.html
PostPosted: Tue Aug 03, 2004 5:12 pm
so whats the word guys
I should enable NETBIOS?
Is that the answer to my woes?
or not..
PostPosted: Tue Aug 03, 2004 5:27 pm
INFINITE vCORE
INFINITE vCORE
or not..
I would say yes. It's worth a try anyway...
..."NetBIOS stands for Network Basic Input / Output System and is a set of rules defining services for PC based networks originally created by IBM. Microsoft operating systems such as NT, Windows for Workgroups and Windows 95 communicate usi ng NetBIOS names…a NetBIOS name can be upto 15 characters in length (with a 16th set aside to denote which service or command was used when the name was referenced.) The services provided by NetBIOS run over TCP/IP and the rules for this and Ne tBIOS name resolution are defined in RFC 1001 and RFC 1002."...
From http://www.ussrback.com/NT/docs/netbios.htm
PostPosted: Tue Aug 03, 2004 7:29 pm
I dont think NetBIOS is your problem.
I dont have it on my PC and our network works fine.
I think you need to try tunning static IPs. I've had problems with DHCP sometimes, so I would try that first.
PostPosted: Wed Aug 04, 2004 7:46 am
excuse my ignorance, but do you mean assigning each comp its own IP under TCP/IP properties?
or through the router?
The thing I never really understood is that I possibly may have to open some ports on the router, but I dont know which ones!
You guys have any idea?
PostPosted: Wed Aug 04, 2004 8:19 am
or not..
Sorry, I didn't get back this...Completely forget about this thread.
They are seeing each other and I suspect if you hit them by IP, you'll see the shares you're looking for...but only by IP as you're not having any name resolution occuring there.
Anyhoo, yes, you either want to either enable netbios and open the respective ports so the computer browser will chatter back and forth some...or go with statics and add an entry to your hosts file reflecting the machine name and IP that you have assigned to that box.
The hosts file does have an example entry in there. If you don't know where it is, use the find utility to find this file.
PostPosted: Wed Aug 04, 2004 9:56 am
Yes, go into TCP/IP properties and set the IPs manually.
Go to start -> run -> type "cmd" (without the quotes) and hit enter -> type "ipconfig /all" (again, without quotes), and hit enter
Write the following info down:
DNS servers
IP address
Default gateway
Now, go into TCP/IP properties, and put in this info:
IP address: use 192.168.x.10 (you need to use the third number from the ip address you wrote down earlier, its going to be a 1 or a 0)
Subnet mask: 255.255.255.0
Gateway: you wrote this down earlier, but its going to be 192.168.1.1 or 192.168.0.1
DNS Adresses: you wrote these down earlier as well.
The IP Adress should not be the same on both machines, the last number needs to be different, ie, Comp1: 192.168.1.5, Comp2: 192.168.1.15, all other numbers will be the same.
See if that works.
You should not have to worry about opening ports to get your LAN to work properly.
PostPosted: Wed Aug 04, 2004 10:18 am
coffee wrote:
yeah same workgroup
They dont see each other
meaning
one computer doesnt see the other when i go to
"view workgroup computers"
Sounds like they're both wanting to be master computer browser, but for some reason neither is showing the other computer? Try going to one of the computers and disabling the Computer browser service.
Start>Run, then type services.msc
Double click on 'Computer Browser'.
Press the stop button, then change the Startup type to 'Disabled'.
You only need to do this on one computer.
That might clear things up.
You *should* be able to access the other computer by manually typing
\\computername\sharename
Obviously you'd replace computername with whatever you named your computer and sharename with whatever you named the shared drive/folder on that computer.
Hope this helps.
PostPosted: Mon Aug 09, 2004 7:38 pm
OK I guess I was just missing the Netbios protocol
Fixed everything!
Thanks for all your help guys!
