It is currently Sat Apr 25, 2015 4:06 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: cant see each other
PostPosted: Fri Jul 30, 2004 5:56 pm
here's the scenario:
2 comps running XPpro
connected to my
DLINK 704P router
>file/print sharing enabled
>logging is through password
>network name assigned
>both comps named differently
>both access web no probs
>drives are set-up for sharing
yet they cannot see each other!
could this be a problem in XP or with my router?
Do I need to open certain ports on the router for the two comps to see each other etc?
Thanks in advance for any help.
PostPosted: Fri Jul 30, 2004 6:58 pm
"yet they cannot see each other! "
Be a little more specific here.
What's giving you the impression that they're not seeing each other??
My first thought is, yes...you need to configure your firewall and router to accept traffic like that...my other thought is you're just not resolving a machine name and maybe hitting by IP would show you some love.
PostPosted: Fri Jul 30, 2004 7:00 pm
Max [Ph]otographer
Max [Ph]otographer
You didn't say that whether or not they were both in the same workgroup, are they?
PostPosted: Fri Jul 30, 2004 7:55 pm
yeah same workgroup
They dont see each other
meaning
one computer doesnt see the other when i go to
"view workgroup computers"
PostPosted: Sat Jul 31, 2004 3:28 am
Well, it seems you have checked and double checked anything I would say. Odd indeed. The router should be handling it just fine, and shouldn't be interfering.
I guess you could call this a bump to the top.
PostPosted: Sat Jul 31, 2004 6:27 am
Can you Ping the other machine by IP??
PostPosted: Sat Jul 31, 2004 7:37 am
yeah I can ping the other comp.
also I disabled SIMPLE FILE SHARING.
I'm at a loss....
could it be a time issue?
i.e.
takes them 15 mins or so to see each other? Although that doesn't seem right.
PostPosted: Sat Jul 31, 2004 7:41 am
Are you running a firewall on either machine? You need to make sure your LAN is in the trusted zone.
PostPosted: Sat Jul 31, 2004 9:33 am
try doing performing the "setup a home or office network" again and see what happens. reboot each computer also. if you are running zonealarm, make sure both LAN IPs from each computer is on its trusted zone. when you click on "add" in zonealarm, you will need to click on "subnet" and then add the IPs.
kinda weird though that it takes 15min for each comp to see one another.
PostPosted: Sat Jul 31, 2004 2:23 pm
Look at the lights on the NIC cards...what's lit?
PostPosted: Sat Jul 31, 2004 5:52 pm
he did say that both PC's can access the internet...
Have you actually shared any folders on the PC's yet?
PostPosted: Sat Jul 31, 2004 6:44 pm
Contributing Writer
Contributing Writer
I'm eager to see how he replies to Someguy. This sounds like a definite firewall issue.
PostPosted: Sat Jul 31, 2004 6:54 pm
ok...well they are seeing each other then.
Can you try to hit the other machine by IP by doing a \\192.168.X.X (or whatever the IP is) from the run line??
You're either looking at opening some ports for machine communications or putting an entry in your hosts file for the machine name and IP so it resolves back.
Since you disabled simple sharing, you'll probably want to setup an account name in the user manager also.
PostPosted: Sun Aug 01, 2004 8:09 am
I'm at a loss....
i.e.
Make sure the IP addresses are the same except for the last number. Also make sure that your subnet mask and default gateways are the same for the IP configuration on both machines. Even if they are on the same workgroup this will prevent them from seeing each other through windows.
I have had experiences with this at my work when people have thought it was fun to change computer settings related to the IP and network.
PostPosted: Sun Aug 01, 2004 2:01 pm
:p...not my week at all.
I'm wondering if he's disabled any services as per the magazine as well. IPrenew worth a shot ya think?
PostPosted: Sun Aug 01, 2004 10:05 pm
i know exactly what you mean. i used to have the same problem. the dumb part is that i could never get it to work unless i have the workgroup set to WORKGROUP. i know it sounds pretty stupid, but give it a try and see what happens. i could not figure it out and i even took a computer networking class. but sometimes WinXP is just quirky like that.
PostPosted: Mon Aug 02, 2004 7:57 am
If you have XP home, then yes, you cannot change your workgroup name from the default.
PostPosted: Mon Aug 02, 2004 8:36 am
wow thanks for all the responses guys.
I'm running XPpro on both machines....
But I tried renaming to WORKGROUP...to no avail
Both comps are through a DLINK DI-704P router,
so it assigned the same string of IP numbers...thats ok...and they can both ping each other...
file sharing is enabled/files and disks set up for sharing
No firewalls on the OS side
could there be one in the router?
i'm thinking it could be the router not the OS thats stopping me from seeing other comps...
should I re-enable SIMPLE FILE SHARING?
CHUMLY...what do you mean??
"disabled any services as per the magazine as well. IPrenew worth a shot ya think?"??
BALDEAGLE...Both machines on same subnet etc...gateway is also the same.
FURBALL can you expand on this..
"You're either looking at opening some ports for machine communications or putting an entry in your hosts file for the machine name and IP so it resolves back. "
Thanks
PostPosted: Mon Aug 02, 2004 8:58 am
INFINITE vCORE
INFINITE vCORE
Can you open shares by typing \\MACHINENAME\SHARENAME in the RUN box?
Is NetBIOS or WINS enabled on the internal network?
PostPosted: Mon Aug 02, 2004 12:48 pm
1) Dont enable simple file sharing.
2) Make sure both PCs have a user name and password that is the same on both. Also create a shared folder on both PCs.
3) If you're using DHCP, try using static IPs just to rule that out.
4) Go to start -> search -> select "computers or people" -> a computer on the network -> search for the network name of the other PC, see if it turns anything up. If it does, browse through it, then see if it shows up in My Network Places. Sometimes you have to give it a helping hand...
