It is currently Sat Apr 25, 2015 10:36 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jul 31, 2004 6:45 am
good, did it work??? i was also wonderig where you were copying from, the hard disk or cd, if the burner and the source are on the same cable both devices cannot be accessed at the same time, and may cause a slodown, with the source and burner on different channels you should get top speed, based on the compatibility of the media and burner.
PostPosted: Sat Jul 31, 2004 8:56 am
Belboz99 wrote:
Well, it seems that I have found what went wrong. I foolishly went to Abit-USA thinking that it would be best to get some chipset drivers for my specific mobo. Turns out those drivers are well over a year old.
So, I took a virtual trip to Nvidia and found that they had some unfied drivers that were very up to date. Go Nvidia!
I do wish that Abit would keep their drivers up to date. :?
Thanks all. I just need to install these drivers and my problem should be solved! :D
Thanks again,
Dan O.
Yeah, go to the chipmaker when you can for drivers. For BIOS releases and such, you're pretty much limited to the motherboard manufacturer.
PostPosted: Sat Jul 31, 2004 12:43 pm
Thanks again,
Dan O.
Was the drivers the problem? Im surprised that Abit had the old drivers on their web site still, this SCSI issue, was a long time ago :roll:
PostPosted: Sat Jul 31, 2004 7:40 pm
Max [Ph]otographer
Max [Ph]otographer
Thanks guys,
Yeah, that driver was old, over a year old. As for where I was burning from and too, I eplained that in my first post.
I was burning from a HDD on one IDE cable onto the DVD+/-RW on the other IDE cable.
I have yet to try burning the ISO again though. Maybe I should do that now just to see what happens.
Well, at the very least, Windows now sees all my IDE drives as IDE, not SCSI.
Thanks,
Dan O.
