It is currently Thu Mar 05, 2015 2:28 am
 Post subject: Windows update error: Code 8024200D
PostPosted: Tue Feb 12, 2013 9:52 pm
I have tried running the windows system readiness tool and it still doesn't work.
This is with update KB2560656,a security update for Win 7 for x64-based systems.
 Post subject: Re: Windows update error: Code 8024200D
PostPosted: Wed Feb 13, 2013 4:29 am
You can try the Microsoft Fix it Tool - the link will point you to the tool specific to Windows Update issues.
It works about 50% of the time, so it's not perfect.
This Windows Update Error KB has some other links you can try as well.
Hope this helps.
PostPosted: Wed Feb 13, 2013 4:59 am
Excellent disclaimer. So true.
This error code signifies a download issue. Turn off your AV and re-download KB2560656 then install. If it still snags, then just alter your BITS.
PostPosted: Wed Feb 20, 2013 7:07 pm
Thanks guys, I will have to try these out and report back.
