It is currently Tue Apr 21, 2015 8:17 pm
 Post subject: Recovering deleted files?
PostPosted: Thu Jul 29, 2004 9:31 pm
I accidentally deleted some files earlier in the week and was wondering what the safest way to recover them would be. I downloaded 2 recovery programs and have yet to try them out as I'm a little wary of the warning. Im on a laptop with only 1 HDD and no other removeable media and the warning says not to recover lost files to the same drive, but doesn't clearly state why. I would only be doing this once and have never done it before. Does anyone know what chance I have of recovering these files and whether or not this could permamently damage this HDD? I can't replace it so that wouldn't be too good.
Thanks.
PostPosted: Thu Jul 29, 2004 10:05 pm
it says not to recover the files to the same drive, because every time u add something to the hard drive, ur risking overwriting the bits of data that are left over from the files u deleted, if it's been a week, u may have already lost them. but go ahead and try anyways, it wont damage your HD.
PostPosted: Fri Jul 30, 2004 6:00 am
Ah, it would be my luck. Im going to try but I dont think they are recoverable, the evaluation versions of the two programs I used arent allowing me to try anyway. I'll have to find another program to attempt it.
PostPosted: Fri Jul 30, 2004 11:04 am
you might want to get a 2.5"-to-3.5" converter and stick the drive in a desktop and run it from there, because just using your PC could over-write your data.
 Post subject: Re: Recovering deleted files?
PostPosted: Fri Jul 30, 2004 11:59 am
Thanks.
Handy Recovery 1.0 from www.simtel.net or Handy Recovrey 2.0 from www.handyrecovery.com. 2.0 is trialware but it lets you recover 1 file a day for 30 days.
PostPosted: Fri Jul 30, 2004 1:59 pm
I had good luck with the handyrecovery 2.0 trial.
It only allows 1 file (of any size) a day, but that was all I needed, and practically every other trial program was limited to 64KB files...
PostPosted: Fri Jul 30, 2004 2:16 pm
I am trying to recover more than one file and with what Deject said in mind I am going to give Handy Recovery 1.0 a try. Thanks all.
PostPosted: Fri Jul 30, 2004 3:02 pm
Here are some tools that I've saved...just in case.
[url=http://www.diydatarecovery.nl/~tkuurstra/irecover.htm]DIY Data Recovery[/ur]
Handy Recovery
PC Inspector
Restoration
PostPosted: Fri Jul 30, 2004 4:59 pm
Handy Recovery 1.0 worked, thanks everyone, it's very much appreciated.
