It is currently Thu May 23, 2013 10:39 am
 Post subject: Corsair H70 Core Cooler Compatibility Problem
PostPosted: Mon Nov 05, 2012 12:27 pm
I have bought a Corsair H70 Core CPU Cooler, it comes with a 3 pin motherboard connector. The problem is that i have a ASUS M2N-e motherboard that has only 4 pin connectors .I need a solution as to how i can make the connection to the mother board. Is there any adapter for 3 pin to 4 pin connector or is there any other solution to make this CPU cooler work?.
 Post subject: Re: Corsair H70 Core Cooler Compatibility Problem
PostPosted: Mon Nov 05, 2012 12:56 pm
You can plug a 3-pin into the 4-pin (it's keyed the same). More info
PostPosted: Mon Nov 05, 2012 1:22 pm
Thanks for the info, that should solve my problem and by the way the fan noise will only be about 19 dcb at full speed. Shawn
