It is currently Wed Jun 19, 2013 11:23 pm
 Post subject: Windows 8 Hard Drive Locked can't get into bios
PostPosted: Fri Nov 02, 2012 7:04 pm
I want to access my BIOS to make sure my boot drive is correct but I am running a Windows 8 system and I can't seem to do it.
I installed Windows 8 on my computer on Tuesday. The past two days it was working fine. I noted the system said there were two updates that would be installed after a restart so I did that. The computer seemed to hang for 10 minutes so I hit the reset button. Now the system says it doesn't know where the boot drive is.
I tried re-installing W8 using my DVD drive and it says the hard drive is Locked.
I am thinking I need to access the BIOS to make sure I have the boot drive is correct. Unfortunately I can't access the BIOS.
I am running:
Intel 2500k
Gigabyte GA-Z77X-UD5H
8G Ram
Western Digital 1000GB Black
Nvidia 460
Thank you for your help.
 Post subject: Re: Windows 8 Hard Drive Locked can't get into bios
PostPosted: Fri Nov 02, 2012 8:39 pm
UPDATE:
I plugged a new keyboard in and I was able to get into the BIOS. The boot order is set up correctly and I still cant access the Hard Drive.
I have also reset the BIOS and still get the same error.
PostPosted: Sat Nov 03, 2012 6:22 am
Grab your manual and flip to page 36
PostPosted: Sat Nov 03, 2012 3:28 pm
I plugged in a new keyboard and was able to access the BIOS screen and the boot order was correct.
I even used Command Prompt to try to get access to my disk but that didn't work.
I resorted to using the Command Prompt to reformat my drive and start over. The problem now is Windows won't let me activate because I am using the disc as a fresh install not an upgrade. I am going to try to get around that.
PostPosted: Sat Nov 03, 2012 5:14 pm
kibbled wrote:
....I resorted to using the Command Prompt to reformat my drive and start over. The problem now is Windows won't let me activate because I am using the disc as a fresh install not an upgrade. I am going to try to get around that.
Yes, I heard the old faithful boot up and kill the install of an upgrade version at the product key and then reinstall no longer works.
Try this.
PostPosted: Sat Nov 03, 2012 5:49 pm
I just re installed W7 made sure it activated and then I installed W8. PITA.
