It is currently Thu May 23, 2013 7:38 pm
 Post subject: SSD failed? in RAID 0
PostPosted: Thu Nov 01, 2012 6:59 pm
last year i build new gaming pc. it is so awesome.
my build is
asrock z77 extreme 4
inter i5 core 2310
16gb ddr3 1600 patriot g2 series
Mushkin Enhanced Chronos 90gb x2 in riad 0 mode
160 gb western digital
2x geforce 250 gt
everything is went smoothly until i start to notice machine start to freeze then i restart but it wont boot up to window keep said bootmgr failed and raid 0 is not bootable but i turn off and on after 5 mins then it is perfect then happen again. i check forum for smiliar plm. i see phrase called ssd power disconnect. it baffled me since ssd is consider more secure and better performer than tradition hard drive. then one morning i see one ssd report error[s] occuring but machine said drive c is bootable and it did boot to window. it been happen for months. forum give me vague answer beside disconnect machine for one hour then turn on.
http://www.newegg.com/Product/Product.a ... 6820226290
that is SSd i purchased for raid 0
 Post subject: Re: SSD failed? in RAID 0
PostPosted: Tue Jan 29, 2013 4:28 pm
BUMP
PostPosted: Tue Jan 29, 2013 5:20 pm
Awkkk! Capitalization exists for a reason! It's a tool, don't be one, so use it. Capitalization is the difference between helping your uncle jack off a horse and helping your Uncle Jack off a horse.
Okay, WELCOME! Welcome to the MaxPC FORUMS. Please make sure you don't just play a voyeur - be sure to actively contribute, advise and help someone else out. This place is only as good as it's participants - it's all about quality and timely I/O.
Now on over to your issue, I must ask the obvious for going to deep. Do you have the latest bios? Your raid drives are set to ACHI? And your OS partition is separate from your data and the MBR?
PostPosted: Tue Jan 29, 2013 6:31 pm
i apologized for capitalization. i spill Chocolate drink on the,m which make it be lesson of make sure your grip is firm with glass when you read shocking new or whatever
to my issue
yes i follow manf instruction to letter. i make sure in bios which i upgrade to very latest to ACHI mode in raid mode
OS partion is on same SSd. i ma not sure if you mean on separate SSD or partion within Raid O
PostPosted: Thu Jan 31, 2013 3:03 pm
bump :roll:
