It is currently Thu May 23, 2013 1:59 am
 Post subject: Problem executing a batch file?
PostPosted: Mon Oct 29, 2012 4:48 pm
I have a batch file that works on my mom's computer with a Celeron Processor and specs to match it that came out when Vista first came out, and my school computer, but it doesn't work on my computer. And I am certain that the batch file does more than it does on my computer before it crashes.
What this batch file does is compiles scripts for a game and puts them into the corresponding file as two files gameexe.dat and scene.pck.
This is the batch file here: http://www.mediafire.com/?56bee1j6detzj5t
And here is the .exe that crashes: http://www.mediafire.com/?940xffgxr6c9qw2
set RewriteDirectory="C:\Program Files (x86)\Key\Rewrite"
cd tools\
encryptdat.exe ../Gameexe.ini ../Gameexe.dat
@echo off
mkdir ..\Scene-EN\SceneNew >nul 2>&1
for %%s in (..\CodeFiles\\*.ss) do echo Inserting %%~nxs... && utf2uni.exe "..\Scene-EN\%%~ns-str.txt" "uni-temp.txt" && ssinsert-v200.exe "%%s" "uni-temp.txt" "..\Scene-EN\SceneNew\%%~nxs"
copy /Y ..\CodeFiles\var*.dat ..\Scene-EN\SceneNew\var*.dat >nul 2>&1
copy /Y ..\CodeFiles\list.dat ..\Scene-EN\SceneNew\list.dat >nul 2>&1
@echo Finished inserting scripts
createpck.exe "..\Scene-EN\SceneNew" "..\Scene.pck" -e
@echo on
@echo Finished packing new Scene.pck
cd ..\
move /Y Gameexe.dat %RewriteDirectory%
move /Y Scene.pck %RewriteDirectory%
The folder I copy it into is as follows:
http://puu.sh/1kjHl
And here are the errors I get:
http://puu.sh/1kiVa
After clicking: Close program, I get this for a split second (Recorded using a screen capture program)
http://puu.sh/1kjIr
And this is a list of the files in the folder:
http://puu.sh/1kjOj
Inside the codefiles folder: (This is what is used, I believe)
http://puu.sh/1kjLY (All the vars files are .dat)
And just in case it's needed, here's the files in the Scene-EN folder:
http://puu.sh/1kjRE
and inside the SceneNew folder:
http://puu.sh/1kjSx
I've already done a complete factory restore from disc (Had to download the drivers as well) by deleting everything everything in my partitions, thus starting completely fresh, and this same problem occurred before and after I did the factory restore.
It works for everyone else on the team, and every computer except the one I use! Please help!
If needed, my computer info is as follows:
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7601 Service Pack 1 Build 7601
System Manufacturer Alienware
System Model M17xR3
System Type x64-based PC
Processor Intel(R) Core(TM) i7-2820QM CPU @ 2.30GHz, 2301 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Alienware A12, 8/20/2012
SMBIOS Version 2.7
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name linktriforce-pc\linktriforce007
Time Zone Central Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 11.0 GB
Total Virtual Memory 31.9 GB
Available Virtual Memory 26.0 GB
Page File Space 15.9 GB
Page File C:\pagefile.sys
Name Intel(R) HD Graphics 3000
PNP Device ID PCI\VEN_8086&DEV_0126&SUBSYS_04BA1028&REV_09\3&11583659&0&10
Adapter Type Intel(R) HD Graphics Family, Intel Corporation compatible
Adapter Description Intel(R) HD Graphics 3000
Adapter RAM (2,084,569,088) bytes
Installed Drivers igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver Version 9.17.10.2867
INF File oem29.inf (iSNBM0 section)
Color Planes Not Available
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xCE400000-0xCE7FFFFF
Memory Address 0xB0000000-0xBFFFFFFF
I/O Port 0x00007000-0x0000703F
IRQ Channel IRQ 4294967294
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\igdkmd64.sys (9.17.10.2867, 5.10 MB (5,343,584 bytes), 10/10/2012 2:22 AM)
Name NVIDIA GeForce GTX 460M
PNP Device ID PCI\VEN_10DE&DEV_0DD1&SUBSYS_04BA1028&REV_A1\4&361D66C5&0&0008
Adapter Type GeForce GTX 460M, NVIDIA compatible
Adapter Description NVIDIA GeForce GTX 460M
Adapter RAM 1.50 GB (1,610,416,128 bytes)
Installed Drivers nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver Version 9.18.13.697
INF File oem22.inf (Section098 section)
Color Table Entries 4294967296
Resolution 1920 x 1080 x 60 hertz
Bits/Pixel 32
Memory Address 0xCC000000-0xCE0FFFFF
Memory Address 0xC0000000-0xCBFFFFFF
Memory Address 0xC8000000-0xCBFFFFFF
I/O Port 0x00006F80-0x00006FFF
IRQ Channel IRQ 16
Driver c:\windows\system32\drivers\nvlddmkm.sys (9.18.13.697, 12.82 MB (13,443,944 bytes), 10/8/2012 11:42 AM)
Drive C:
Description Local Fixed Disk
Compressed No
File System NTFS
Size 1.36 TB (1,500,200,824,832 bytes)
Free Space 695.37 GB (746,646,679,552 bytes)
Volume Name
Volume Serial Number C42A8021
Drive D:
Description CD-ROM Disc
 Post subject: Re: Problem executing a batch file?
PostPosted: Sun Nov 11, 2012 5:19 pm
Have a moderator move this post to the proper forum and I am sure you will get your answer:
viewforum.php?f=23
