It is currently Wed Jun 19, 2013 11:23 pm
 Post subject: How to turn my .vcd files back into .dat?
PostPosted: Sat Oct 27, 2012 7:48 pm
I installed Media Player Classic, and once I did, all my .dat files turned into .vcd. Is there any way to turn them back?
My OS is Windows 7 Ultimate.
 Post subject: Re: How to turn my .vcd files back into .dat?
PostPosted: Sun Oct 28, 2012 8:28 am
Xmedia Recode
http://www.xmedia-recode.de
PostPosted: Sun Oct 28, 2012 8:43 am
kleinkinstein wrote:
This won't work. I'm asking for a permanent fix as to how to change it back, not how to change an individual file back one-by-one.
PostPosted: Sun Oct 28, 2012 9:32 am
I'm going to assume that the .dat file is a video file, and not one of the 20+ other uses for the extension. In which case if it is a video file, it's usually VCD anyway.
Keep in mind, if any actual conversion is being done, then you kind of don't want to reconvert it if you want to preserve the quality.
PostPosted: Sun Oct 28, 2012 11:32 am
Well, it changes file types depending on which program I use on it for default. (I used media player classic, which changed it to VCD. My parents computer which doesn't have MPC lists it as a .dat file)
The link to the file is here:
https://dl.dropbox.com/u/2149346/Gameexe.dat
PostPosted: Sun Oct 28, 2012 12:21 pm
Yup!....you're fucked!
PostPosted: Sun Oct 28, 2012 1:38 pm
you're not helpful at all. I'm far from "fucked" because my computer is still running.
PostPosted: Sun Oct 28, 2012 3:24 pm
I say don't worry about it if you can play it.
PostPosted: Sun Oct 28, 2012 4:22 pm
"Play" it? I don't think it's a file that can be "played".
PostPosted: Sun Oct 28, 2012 5:22 pm
Open up MPC, go to File -> Quick Open, change file type to all, then go find your .vcd files and open them.
PostPosted: Mon Oct 29, 2012 2:40 pm
"cannot render the file"
Not that that's a big problem or anything.
