It is currently Fri Jan 30, 2015 8:29 am
 Post subject: Java Runtime Environment
PostPosted: Wed Jul 28, 2004 10:03 pm
I am looking for a smaller install of the JRE. Sun Java is over 100 mb and changes the look and feel of some windows objects. Since Microsoft does not support java is it a good idea to track down the old MSVM? :shock: :?:
PostPosted: Wed Jul 28, 2004 10:20 pm
ummm am I missing something the "offline installation" for the windows JRE
http://java.com/en/download/manual.jsp appears to be only 15~MB. not tiny certainly but not 100MB's
 Post subject: Re: Java Runtime Environment
PostPosted: Thu Jul 29, 2004 12:58 pm
Bitchin' Fast 3D Z8000*
Not exactly a prodigous start - even the SDK is half the size you imagined. And what 'windows objects' are you refering to? The Sun JRE does not change any of you currently installed software.
