It is currently Tue May 21, 2013 6:22 pm
 Post subject: Lose video, then lock up
PostPosted: Thu Oct 11, 2012 12:22 pm
Hi all, wondering if someone can help me with this issue I'm having.
When Playing two different games (Dishonored, and Borderlands 2), within 30mins to an hour I suddenly lose my video signal to the monitor. There is still sound (like the game is still running), for 5-10 seconds, but then that stops and sounds like it locks up (studdering sound). The computers fans still run, but everything else is unresponsive. I have to disconnect power to reboot.
I checked the usual suspects. PSU is fairly new, reseated all my cards, and memory, even rolled back my video drivers to 12.6. Still nothing helps. The odd part is i can run BF3/Civ5/GW2 (on highest settings) for hours on end, with no issue. It seems only those two games are affected (haven't tried Borderlands 1 yet, but am still currently downloading).
If anyone can help me with some ideas, it would be greatly appreciated, 'cause I'm stumped. Thanks in advance.
My system:
Win7 (64)
8gb ram
Asus radeon 7950 (stock)
i7 2600k (stock)
creative x-fi
 Post subject: Re: Lose video, then lock up
PostPosted: Sun Oct 14, 2012 12:41 pm
It may be a heat issue. Try taking the side of the pc off, point a house fan at the opening and run the offending apps, if the apps run you know you have a heat issue. Are your apps fully patched?
PostPosted: Sun Oct 14, 2012 1:39 pm
Also try getting the latest driver, and see if that helps. http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_vista64.aspx
PostPosted: Sun Oct 14, 2012 8:17 pm
I have checked temps running Dishonored vs. BF3. BF3 runs a little hotter, but still not too high. I still can play BF3 continusly, and yet only get 30mins (at most) playing Dishonored before this problem comes up. I do notice my temp2 on Speedfan shows around 50*C-60*C, but I've read that this is in error.
I am now running 12.8 drivers for my Gfx card, still no change.
...any thoughts?
