It is currently Tue Mar 03, 2015 1:20 pm
 Post subject: msmsgs.exe is annoying me
PostPosted: Wed Jul 28, 2004 8:38 am
msmsgs.exe constantly runs on my PC. I can't figure out what is calling it to start up, and when I try to exit, it says it can't because an application is still using it... this happens even when no apps are running. If I end-task it, it starts right back up again, within 2-3 seconds. I've renamed it ms_msgs.exe so that whatever is calling it to start couldn't find it. Now in the event manager it gives some sort of DCOM error related to msmsgs. Any ideas anyone?
TIA,
Bill
PostPosted: Wed Jul 28, 2004 10:21 am
Try running:
-A Spyware program, like Spybot Search & Destroy 1.3 or Lavasoft's Ad-aware 6.0
-An Anti-Virus program, like AntiVir or AVG AntiVirus
-A Registry Repair program, like Registry Mechanic or WinASO's Registry Optimizer
If your problem still isn't fixed after you've tried all 3 types of those programs, come back and tell me.
(P.S. You can find most of those programs at http://www.download.com)
PostPosted: Wed Jul 28, 2004 10:23 am
hmmm.........i dont know if this is the same but try going to start -> run -> type in "msconfig" without the "". when you see a gray box come up, click on the startup tab. see if you find the msmsgs.exe there and uncheck it. reboot the comp and see if your problem is solve.
 Post subject: Re: msmsgs.exe is annoying me
PostPosted: Wed Jul 28, 2004 10:24 am
TIA,
Bill
http://www.liutilities.com/products/wintaskspro/processlibrary/msmsgs/
are you using MSN Messenger? uninstall it if not.
PostPosted: Wed Jul 28, 2004 10:26 am
www.grc.com
he has a bunch of tools that are really easy to use
PostPosted: Wed Jul 28, 2004 10:54 am
I use messenger, but infrequently. I have no idea why it wants to keep starting itself. In Outlook 2003, I have it set to not log into messenger, but I don't find any setting about it starting up that process.. and the program starts with windows, upon boot. It is not in MSCONFIG, nor is it in my registry as a startup program. I routinely run Spybot S&D, adAware, and spyware blaster. I update & run them regularly. My PC is clean, and it's actually a fairly fresh install (couple weeks old re-install on formatted & fdisked drive). I have NAV2004 & it updates regularly. I am fully updated as per windowsupdate.
Bill
PostPosted: Wed Jul 28, 2004 11:45 am
i noticed that msmsgs.exe always starts up when i open Outlook 2k3 and Outlook express. No virus, no sh*tware, just a ploy by M$ to consolidate all your email, text, IM to one neat package. May be wrong tho...
PostPosted: Wed Jul 28, 2004 4:14 pm
I found this answer in another forum:
Start / Run / services.msc
Stop the Messenger service and set it to Disabled.
Simple as that! I love Google!!
PostPosted: Wed Jul 28, 2004 6:41 pm
http://www.maximumpc.com/forum/viewtopic.php?t=754
Read what superchip posted to my issue with MSN messenger.
PostPosted: Wed Jul 28, 2004 8:14 pm
I'm really amazed that it was this far down the thread before someone got it right...
START/RUN/MSCONFIG may stop it, but it will recheck itself at reboot. like Nasty said, disable the SERVICE.
oh, btw....
this has NOTHING to do with the MSN MESSENGER Instant Messenger program, it's a pop-up network messenging utility; disabling it will have NO EFFECT WHATSOEVER on ANY other program (.NET or otherwise).
for more info on trimming your machine, visit ;
www.blackviper.com
PostPosted: Wed Jul 28, 2004 9:59 pm
Phoenix Foundation (Top 10)
MSMSGS is the windows messenger, not the MSN version. If you dont use messenger, you can boot to safe mode and delete the messenger folder from the program files folder. Thats how i do it on my pc and all the new ones i work on, works great, never loads again, lol.
You can also run MSNCONFIG and disable it under RUNNING SERVICES.
 Post subject: service
PostPosted: Thu Jul 29, 2004 3:53 pm
it IS set to disabled... yet it continued to load up, until i renamed the file!!??
PostPosted: Fri Aug 13, 2004 10:33 am
nobody else has any ideas?
PostPosted: Fri Aug 13, 2004 10:44 am
This is the windows messenger as has been said, and tweakXP has an article on how to remove it from your system: http://tweakxp.com/display.aspx?id=487
That will physically remove it and its library file from the system, so be sure you don't use or need it before you do this.
*edit* here is another for disabling it: http://tweakxp.com/display.aspx?id=585
