It is currently Sun Feb 01, 2015 6:08 am
 Post subject: bios freeze?
PostPosted: Sun Sep 30, 2012 1:14 pm
This is really getting annoying. Whenever my dads pc gets rebooted it will hang at the the BIOS page that says press F10 for boot select and stuff and just stays there forever. If you do hit F10 it takes a while then goes into boot select and sometimes if you go to the hdd and hit enter it will take a bit then boot. Other times you just have to keep doing that till it does. Any ideas why it does this?
 Post subject: Re: bios freeze?
PostPosted: Sun Sep 30, 2012 1:43 pm
Sounds like the comos battery is dead and needs to be replaced, when that is done go into the bios and set optimum defaults, save and exit. This should fix the boot-up mess.
