It is currently Wed May 06, 2015 2:43 pm
 Post subject: forgetting folder settings
PostPosted: Wed Jul 28, 2004 4:32 pm
Hi ya :)
Im using am 160 gig drive that i always put my data on as drives D and E.
Anyways, I did a install of windows xp again, and when i go into my music files everything is listed by name size, track year, etc etc. How do i change it towards where i can get the folder to display the music as Name, Type, Size, and modified? I really need it to do modified, thats the easiest way i can find my music files. I have formatted the drive too, but it still comes up with the track name size, year, etc stuff.
If u dont understand what im saying, ill gladly post pictures.
Thanks :D
PostPosted: Wed Jul 28, 2004 6:41 pm
hello I believe if I'm understanding you correctly?
if you goto view (details)
then right click in the grey area right above the files and select "modified" if needed then you can click the modified colum to sort assending / dessending as needed on these files.
post screen shot if this didn't help.
peace.
PostPosted: Wed Jul 28, 2004 8:07 pm
no but thanks for trying :D
This is what i want it to do. See the whole drive views everything as this
PostPosted: Wed Jul 28, 2004 8:08 pm
it also does this in the music folder
and i want all thesee options to change to this
The only way i could do it before was make the folder, then set it to auto arrange, then set it to modified and then put music in, then the music would stay the modified say. But this time the whole drive does it, so i dont know what to do. (oh and sorry if im not allowed to post pics)
Thanks
PostPosted: Thu Jul 29, 2004 12:47 pm
bump
PostPosted: Thu Jul 29, 2004 1:04 pm
Resize your images. No more than 640 pixels horizontal.
You might want to take a look at the rules.
Oh ... and do it quickly.
