It is currently Tue Mar 03, 2015 1:25 am
 Post subject: New Video card doesn't work?
PostPosted: Fri Sep 28, 2012 7:01 am
I have a Gateway computer that I took the video card out of to use else ware. I purchased an EVGA GT520 from Newegg. In the install notes it said to uninstall old drivers and disable any on board graphics. I installed the new card, rebooted and … nothing just a black screen. I have a Viewsonic monitor VX2235wm that can switch between analog and digital so I make sure its on digital. Still nothing. The screen just says no analog signal. So far the only way I can get an image is to change the cable to the VGA cable. In device manager it says under monitor, Generic non-plug and play, under Display adapter it says VGA disabled but doesn't even show the new card at all. I tried installing drivers for both items and it says not product found associated with these drivers.
I'm stumped as to what I should do next. Any suggestions?
This computer info:
Processor Intel® Core™2 Quad Processor Q9300
Each core operates at 2.50 GHz
6 MB L2 cache
1333 front side bus
System Memory1 Up to 8 GB of DDR2 667/800 MHz SDRAM (dual-channel support on four DIMMs)
Hard Drive Serial ATA hard disk up to 1 TB1 per 3.5-inch drive
Optical Drive1 Optical drive options:
DVD-SuperMulti with Labelflash™ support
Blu-ray™ ROM Combo DVD-SuperMulti
Blu-ray R/W Combo DVD-SuperMulti
Graphics ATI Radeon™ HD 4850 graphics, featuring:
DirectX 10
Shader Model 4.0
ATI Hybrid Graphics
ATI Avivo™ HD
ATI PowerPlay™
ATI SurroundView™
Audio Embedded high-definition audio with 7.1-channel audio support
Networking 10/100 Ethernet
I/O Ports Front:
Two USB 2.0 ports
15-in-1 card reader2
Headphone and microphone jacks
RCA analog video input2
Two RCA stereo audio inputs2
Rear:
Four USB 2.0 ports
1394a port
Ethernet (RJ-45) jack
Six audio jacks
D-sub VGA port
eSATA port
Two PS/2 ports
I/O Expansion One PCI Express® ×16 slot
One PCI Express ×1 slots
Two PCI conventional slot
Power Supply 400 W
 Post subject: Re: New Video card doesn't work?
PostPosted: Fri Sep 28, 2012 7:27 am
XP or Win7?
PostPosted: Fri Sep 28, 2012 7:31 am
1. Did you change the monitor's input to force it to use DVI instead of auto-detect?
2. If there's anything considered a primary output, is the cable plugged into there?
PostPosted: Fri Sep 28, 2012 1:02 pm
Windows 7 64bit
Yes I forced it to change to DVI, through the on screen menu. On the back of the monitor are 2 outputs, one for DVI and one for VGA.
