robertco300 wrote:
1. I have VLC Player installed on my SSD AND the other drive that has Win 7. If I boot to the SSD but select the VLC Player off the other hard drive, will ONLY that drive be running and NOT the SSD? Thought it would be good to divy up the workload.
If the program is run from the hard drive, then yes. Make sure your shortcuts are pointing to that.
Quote:
2. Freshly installed SSD, I had a few crashes doing simply things like watching HD tv and NOTHING else. Wasn't like I was multi-tasking or anything. So I went into AMD Catalyst Control Center and turned off the Overdrive settings. Been pretty solid ever since. Is there any history there with vid card overclocking and SSD's?
No, it sounds more like your video card was f'ing up. You video card may be doing decode work, not the CPU. It depends on the crash too, because saying "crashes" could mean anything.
Quote:
3. I have the SSD for a fast OS, so I can cruise the net much faster and increase the rate of my downloads. This is why I thought it was important to go to the other hard drive and run VLC Player from it and I wanted to know if I am wasting my time or not. You see what I am trying to do? Is it really happening or not?
You are wasting your time. Your internet speed is not related to your secondary memory speed. The only speed improvement you'll see on browsers may be opening the browser itself, initializing plugins (like Flash or Silverlight), and snappier user experience when multitasking. And that's it.
Your download speed for all intents and purposes is
always going to be slower than even a dinky 5400RPM hard drive.
This might matter if you were transferring files between computers over the network, but unless your using Gigabit Ethernet, even your LAN/WLAN won't beat a hard drive.
