It is currently Mon May 04, 2015 7:17 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: Linux again
PostPosted: Tue Jul 27, 2004 9:41 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I tryed what you said in my earlyer post. I set the boot to my cd rom drive. Its still not working though. My choices for primary boot are Floppy ARMD-FDD ARMD- HDD and AdapI CDROM It is set at the cdrom but it still wont boot the disks.
PostPosted: Tue Jul 27, 2004 9:52 pm
hi when you set it to "CD" you did select exit saving changes right?
what happens when the CD is in the drive and you try to boot (i.e. does it say anything about hitting a key to boot from cd?)
PostPosted: Wed Jul 28, 2004 7:25 am
7yrs+11,000 Posts
7yrs+11,000 Posts
Yes, i saved my settings. and when i boot up it reads the disk, takes a a little time doing that, and then loads windows. I dont get why its doing that.a I have two cd rom drives one being my burner and neither of them work.
PostPosted: Wed Jul 28, 2004 10:32 am
sounds like a problem with the CD.
PostPosted: Wed Jul 28, 2004 5:07 pm
Are you trying to use an image to load Linux? If you are, you must run the image in windows (just double click on the icon) so it can pick up your burning program and make a bootable cd. Do this for all the images you have.
PostPosted: Wed Jul 28, 2004 6:05 pm
Exactly what have you been downloading??
PostPosted: Wed Jul 28, 2004 6:26 pm
this time, you can try making another bootable linux cd if you can. this time also try downloading clone cd. i use it all the time and it works.
PostPosted: Thu Jul 29, 2004 4:31 am
7yrs+11,000 Posts
7yrs+11,000 Posts
The cd works because i have used it before.
PostPosted: Thu Jul 29, 2004 4:59 am
7yrs+11,000 Posts
7yrs+11,000 Posts
and the cd was burned properly cuz it wasnt burned by me
PostPosted: Thu Jul 29, 2004 9:54 am
Gamer: try going into the BIOS again, and in addition to setting the CD-ROM as your first boot option, remove the HD completely from the list. Tell us what it says ... chances are, it won't boot but it should tell you why. :)
PostPosted: Thu Jul 29, 2004 11:06 am
Some motherboards have an option in the bios for legacy operating systems, you might have to enable that option to get the primary ide to work right. As for the cd-rom not detecting the cd, your cd-rom may be too old and needs a firmware flash to read the cd. One other thought is use a linux boot disk in the floppy to load your system.
PostPosted: Sun Aug 01, 2004 2:58 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
:evil: i made the boot disk. didnt work. Took the hd off. Didnt work. Cant find mobo option in bios. It wont stop loading to windows. I want to kill it :twisted: what the hell should i do. Thanks for the advice.
PostPosted: Sun Aug 01, 2004 3:39 pm
Stop using Linux and stick with something you know.
...or at least put forth some effort before asking questions here.
PostPosted: Sun Aug 01, 2004 4:19 pm
Hey Furball!
This forum is for helping people out! Not telling them to do something they know, how the hell are ya going to learn if they don't ask questions? If you don't have something constructive to say ... DON"T!!
PostPosted: Sun Aug 01, 2004 4:37 pm
:::Rolling Eyes:::
My goodness, who gave you a hall pass.
Maybe you should read some of the other posts they've made.
PostPosted: Sun Aug 01, 2004 7:24 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
maybe i wana have linux :x
PostPosted: Sun Aug 01, 2004 7:54 pm
Then start asking some constructive questions, feed on that, and then ask more if you needed.
PostPosted: Mon Aug 02, 2004 6:56 am
7yrs+11,000 Posts
7yrs+11,000 Posts
these are constructive in my terms. I need to do somthing and i am asking questions to help me do that. Maybe you should be giving more constructive ansewers.
PostPosted: Mon Aug 02, 2004 7:00 am
INFINITE vCORE
INFINITE vCORE
Something I have run across:
Some older motherboards won't boot CD's unless they are set as Secondary master...
PostPosted: Mon Aug 02, 2004 4:03 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
thanks for you suggestions i got it to work
