It is currently Sat May 18, 2013 8:00 am
 Post subject: Can SSD Be Flashed?????
PostPosted: Tue Sep 25, 2012 6:41 am
My 3 year old SSD crashed and have since replaced it.
In BIOS, instead of OCZ Agility showing up, it shows up as YOKOMONO ROM. Like it's just a big brick of ROM but since it is being recognized, is there a possibility I could revive it with a simple flash???
 Post subject: Re: Can SSD Be Flashed?????
PostPosted: Tue Sep 25, 2012 7:02 am
I don't know. Why don't you go try it?
PostPosted: Tue Sep 25, 2012 7:15 am
Don't you mean YOKOONO PROM?
PostPosted: Tue Sep 25, 2012 9:23 am
You should be able to, but if you run into trouble, try using Parted Magic to do a secure erase of the SSD before flashing.
PostPosted: Tue Sep 25, 2012 3:14 pm
You might want to check with OCZ, they extended the warranty on some of their SSDs, yours might still be under warranty.
Users browsing this forum: Google [Bot] and 3 guests
