It is currently Sun May 03, 2015 3:13 pm
 Post subject: My acer aspire 7551-7422 keeps shutting down
PostPosted: Mon Sep 17, 2012 2:45 pm
My acer aspire 7551- 7422 keeps shutting down. I have done the following and still it keeps doing it.
1. I have d loaded speed fan and hw Monitor to show if its over heating all is good.
2. I have run check disk nothing came uo also ran ccleaner , defragment,Avg,Malware nothing came up
3. I have deleted all video drivers and reloaded them and t still does it.
4. I have had a computer guy out and he said i needs a new video card which is intergrated with mother board which means a new motherboard and its to expensive to fix.
5. I have d loaded updated bios and it still does it.
Does anyone else have anymore ideas ?? this computer I bought refurbished in Jan. of this yr and really cannot afford to not be with out it.
 Post subject: Re: My acer aspire 7551-7422 keeps shutting down
PostPosted: Mon Sep 17, 2012 6:41 pm
Sounds like a power issue.
I would recommend getting a new power cord/adapter. Probably about $15. Hopefully that will fix the problem.
I realize you need the computer, but it's not much good to you if you can't rely on it. You may want to check out the costs of shipping the computer to Acer and getting it fixed. Either that or you get another computer.
Hope this helps.
PostPosted: Tue Sep 18, 2012 11:52 am
Refurb warranty expired?
You can check the AC converter power output with a VOM. But otherwise I agree the only other thing to try is a new AC adapter, but I would have thought it would have shifted over to battery.
PostPosted: Tue Sep 18, 2012 7:03 pm
What happens when you take the battery out, and just run it off the power brick?
PostPosted: Wed Sep 19, 2012 5:47 pm
FascistNation : What is Vom ? nsvander : I have the battery out now and the power pluged in dont see how this will work when the system runs off of battery but thought I would try
PostPosted: Thu Sep 20, 2012 3:41 pm
bigd7106 wrote:
FascistNation: What is Vom?
VOM
bigd7106 wrote:
nsvander : I have the battery out now and the power plugged in don't see how this will work when the system runs off of battery but thought I would try
And did it?
Users browsing this forum: No registered users and 13 guests
