It is currently Thu Mar 05, 2015 4:19 am
 Post subject: LCD monitor dim after power outage
PostPosted: Tue Jul 27, 2004 1:26 pm
Ok, so the power goes off where I work yesterday, and doesn't come on until about 7:30 last night. Today I come to work, and one of our LCDs on our registers doesn't quite work right. It's very very dim - almost not visible. I can't even see the OSD to adjust the brightness. The thing is, when it's on and unplugged and re-plugged, it turns on as bright as it should be for a fraction of a second, then goes dim again.
The LCD on the other system is unaffected, and works fine on either system. The affected LCD does not work on either.
Is the LCD dead? What could possibly cause this?
*edit*
Oddly enough, it went into "standby" when hooked up to the other system, and when I went back to look at it, it came out of standby and works just fine now. Go figure.
 Post subject: Re: LCD monitor dim after power outage
PostPosted: Tue Jul 27, 2004 1:41 pm
bulbs got popped?
PostPosted: Tue Jul 27, 2004 1:58 pm
bulbs got popped?
Jigga wha?
PostPosted: Tue Jul 27, 2004 2:08 pm
bulbs got popped?
Jigga wha?
Essentially something internal got damaged by the outage. Try a different monitor. There is a chance the video card got damaged so this test will determine if the problem is the monitor or the video card.
PostPosted: Tue Jul 27, 2004 2:10 pm
he already has.
bobtheelf wrote:
Jigga wha?
jigga who?
i was just taking guesses.
PostPosted: Tue Jul 27, 2004 2:30 pm
cigar3tte wrote:
he already has.
Then we now know the problem. video card or AGP slot on the mobo. try adding a new, working video card.
