It is currently Tue Jun 18, 2013 8:37 pm
 Post subject: Need Help Finding This Program
PostPosted: Mon Sep 03, 2012 6:39 am
I lost access to my D drive and one of the things on it was the install program for a GREAT media player and for the life of me I can't find it anywhere on the net.
All I know is in Task Manager, the executable was called anyplayer.exe.
I loved it mostly cause if I clicked on a show to watch it would automatically load ALL the shows in it's folder to the playlist and play them all automatically.
Does anyone know what media program this could be? anyplayer.exe. Thanks.
 Post subject: Re: Need Help Finding This Program
PostPosted: Mon Sep 03, 2012 8:42 am
I hate to sound like a hypocrite after having been fed up with the "install [my program of choice]!" for "fixing" a problem, but you could achieve the same effect (more or less) by highlighting all the files and opening them with any media player.
Or if going by the process name: http://anyplayer.findmysoft.com/ or http://www.softpedia.com/get/Others/Mis ... ayer.shtml
PostPosted: Mon Sep 03, 2012 7:34 pm
Neither of which are the program I was using. What.....you think I didn't do a basic Google search at first to find this program??? Dunce.
PostPosted: Mon Sep 03, 2012 11:25 pm
I'd expect you to not be so anal about a feature that every media player will basically do anyway. Highlight files, right click, open with media player of choice. Done.
PostPosted: Tue Sep 04, 2012 2:58 pm
This program obviously did it better. I one click the tv show I want to watch and the entire folder of shows automatically load onto the playlist and play in order. I've yet to find a media player that does that.
PostPosted: Wed Sep 05, 2012 5:54 am
Ahhh, so you like Fisher-Price software. Linear functionality and big single buttons, no thinking allowed. I'm simply LMFAO that you can't find/recall it but yet refuse to consider anything else. Too funny!
PostPosted: Wed Sep 05, 2012 9:01 am
How would you know what Fisher Price software looks like? By your description you sound like a Fisher Price professional. An I am LMFAOBT cause you have nothing better to contribute to this thread which makes you a LLLLOOOOOOSSSSEEEERRRRR!!!
PostPosted: Wed Sep 05, 2012 9:42 am
Found it. No gratitude needed.
