It is currently Thu May 23, 2013 7:26 am
 Post subject: My PC is very slow to load after I turn it on - Please help
PostPosted: Wed Jun 27, 2012 11:09 am
Hello,
This happened at least for a week now. I have my CC cleaner with me and I clean my PC everyday. Why is it that my PC loads so slow when I turn it on? I would wait 30 minutes for the stuffs in my desktop to load and for it to start and running.
Please advice.
Thanks.
RoyalPen
 Post subject: Re: My PC is very slow to load after I turn it on - Please h
PostPosted: Sun Jul 01, 2012 10:11 am
Can you give us some hardware specifications (CPU, motherboard make and model, etc.), please? What operating system are you using on this computer? Oh, and welcome to the forums, sir!
PostPosted: Mon Jul 02, 2012 4:02 am
....also what anti-virus and anti-maleware are you using?
How many applications do you have running in the system tray?
Did you install a program and this happened after the install?
PostPosted: Mon Jul 02, 2012 1:59 pm
After you provide all of the above, run Soluto and share with us those results.
PostPosted: Tue Jul 10, 2012 9:15 am
Thanks for the replies. My OS is Windows 7. This happened after I installed Microsoft Office 2010 Professional including Microsoft Outlook 2010 and Microsoft Expression Web 4. I have two antivirus running (avast and mcafee) so I have no problem with my unit having a virus.
I don't want to uninstall the Microsoft Office 2010 and EW4 because I am using them.
I'll try Soluto and see if it will make my unit faster.
PostPosted: Sun Aug 26, 2012 12:49 pm
Your big problem is you are running two anti-virus programs! You can't do that, one will fight the other and slow the whole system down. Get rid of McaFee and I will bet the system will run normal after that. Use the uninstall program that McaFee has on their website, NOT the one in control panel!
PostPosted: Sun Aug 26, 2012 2:20 pm
I'm bettin he hit a porn site that had some crazy malware.......
Surprised no one mentioned HiJackThis first. Run this program and I'm sure you'll find tons of crap on your pc that shouldn't be running.
My suggestion............relax on the porn which is the worst place for malware but seriously.....run hijackthis.exe where ever you can find it first. Post an image file of it's scan here for us to see.
PostPosted: Sun Aug 26, 2012 9:16 pm
I agree with Nasty! Remove one or the other of the antivirus programs and you should see your computer return to normal again.
PostPosted: Thu Aug 30, 2012 8:58 pm
I highly recommend this, and also I would go into start>type "msconfig" and then check your startup programs and services.
PostPosted: Mon Sep 03, 2012 4:18 am
Royalpen,
Did you try any of the suggestions above and did they/it work? Some feedback would be nice as we are trying to help. :wink:
