It is currently Sat May 18, 2013 4:39 pm
 Post subject: Using GTX460 with TV
PostPosted: Wed Aug 22, 2012 5:39 am
I know my pair of GTX460's can drive a flat screen TV through an HDMI cable. My question is this. Can I keep a monitor plugged into it through the DVI port and still use the HDMI? And does that gen card also pass the audio through the HDMI port? I am looking to run the HDMI from the video card to my AV Receiver, then to the TV. I am looking into trying the service from www.getfreetv.com that is advertised in this months mag. Thanks in advance...
atr
 Post subject: Re: Using GTX460 with TV
PostPosted: Wed Aug 22, 2012 7:17 am
Yes and yes. But you can only have two outputs on at the same time. So no dual monitors + a TV
