It is currently Thu May 23, 2013 11:01 pm
 Post subject: Where did my sound go?
PostPosted: Thu Aug 16, 2012 11:16 am
Win 7 64 bit
AMD Phenom II x4 945 3.00GHz
ATI Radeon 4870
4GB Ram
SoundBlaster X-Fi Soundcard
Upgraded to 8 gb or RAM by adding 2x2GB of the exact same memory to mother board(all 4 slots are now full). I unplugged all wires including the power supply. Hook all back up reboot everything is great but I have no sound. Volume control shows speakers and lists SB x-fi as the device. Had no problems before hand.
Please help!
 Post subject: Re: Where did my sound go?
PostPosted: Thu Aug 16, 2012 12:12 pm
Did you reconnect to jack cable to the case front panel? Is their audio out the card? Speakers/headphones plugged into the right port? If all is so, then next easiest thing is to uninstall the drivers with Revo or Geek, purge all remnants with CCleaner infused first with CCEnhancer, and then reinstall the latest version off the X-Fi page.
PS. Did you Memtest those new DIMMS?
PostPosted: Thu Aug 16, 2012 12:34 pm
I uninstalled the SB card and re-enabled the on board audio and that works just fine. Is there an issue w/ SB cards and memory?
PostPosted: Fri Aug 17, 2012 5:31 am
OP unresponsive.
Also what MB?
