It is currently Wed Jun 19, 2013 1:21 am
 Post subject: Windows 7 home updates fail
PostPosted: Fri Aug 17, 2012 6:07 am
Greetings,
I can't seem to update Windows 7 on my home machine. Everytime I try, I get a "failed to install" after at the point where I reboot.
I have tried all three of these methods, and nothing works.
Anyone else have any ideas?
 Post subject: Re: Windows 7 home updates fail
PostPosted: Fri Aug 17, 2012 6:29 am
Have you tried to update through Internet Explorer/Tools/Windows Update?
PostPosted: Fri Aug 17, 2012 6:37 am
Yes, and it just does the same thing. Anyone know where I can find an error log to point out which update is causing these problems?
PostPosted: Fri Aug 17, 2012 7:03 am
You may have a virus that is stopping you from updating windows.
Download these apps and then go into safe mode with networking to run them:
http://siri.geekstogo.com/SmitfraudFix.php
Just double click app and follow prompts.
http://www.bleepingcomputer.com/download/combofix/
http://majorgeeks.com/Combofix_d6402.html
http://www.malwarebytes.org/
Choose free copy, download, install, update and run.
All apps must be run in Safemode with Networking to get best results.
