It is currently Thu May 23, 2013 1:45 am
 Post subject: Slow computer, everything seems O.K.
PostPosted: Sat Aug 04, 2012 6:24 pm
A few days ago everything started slowing down. It all started while playing a little game called Diablo 3. Computer completely locked up and hard to do a hard reset. I thought it was D3 related, but began crashing during everyday use. Have checked hard drive, video card, and memory. No hardware changes or newly installed programs. Please advise further action.
Win7 Professional 64-bit
Core i7 2.8
6gb ram
Samsung Barracuda? 1TB
GTX 470 driver version 8.17.13.142
I realize the description of my issue is vague. It's almost like you're watching YouTube and it's still trying to load, with occasional lock-ups. No error reports at all. I'm stumped.
 Post subject: Re: Slow computer, everything seems O.K.
PostPosted: Sun Aug 05, 2012 12:32 am
You do have an active antivirus program and have run a deep scan, right?
When it locked up, did it blue-screen?
Are all fans running, including fans on video card?
Is this an internet issue? Does it act slow when running installed programs that don't access the internet?
PostPosted: Sun Aug 05, 2012 7:16 am
Running Microsoft's Security Essentials, and have ran a full scan with clean results. Will check that all fans are running. It happens when not accessing the internet (or accessing very little...) Plus, would a slow internet or spotty internet connection stall the entire computer? No blue screen or error report.
*All fans are running.
PostPosted: Sun Aug 05, 2012 7:41 am
First run CCleaner infused with CCEnhancer, then run Process Explorer and Monitor to find what is hogging your resources in the background.
PostPosted: Sun Aug 05, 2012 8:42 am
Ran CCleaner, thanks for the information on CCEnhancer, looks like a great addition to an already amazing tool. Standard Windows Resource Monitor shows nothing out of the ordinary hogging resources.
PostPosted: Sun Aug 05, 2012 11:43 am
Natemx wrote:
...nothing out of the ordinary hogging resources.
What was your cpu usage %, commit charge %, # of processes running, and physical usage %? If all in line let's check something quick. It may seem odd, but it could be a hardware connectivity issue. Power down and disconnect then reconnect all your sata cables (both ends) and do the same with your DIMMS. Power on and report back.
PostPosted: Sun Aug 05, 2012 2:44 pm
CPU Usage 1%
Physical Memory Usage 29%
Commit(GB) 1 / 11?
52 Running processes
Will power down and check all plugs...computer hasn't crashed in a days use.
